I wrecked my 97 silverado and bent the frame. Can't sell it though because it's been there for me through thick in thin. I bought a new frame at a wrecking yard and it's being painted ATM. Well I started taking my wiring harness off to take the cab and bed etc off and I realized I'm not going to remember where half these plugs go. My friend has an LS1 383 fully forged crank roller cam etc that he said he will give me. How do I find out how to make this work with the harness I've got? I thought about scraping the harness and throwing on a carburetor but then I started thinking about breaks! I would like any information on what to do next
Sounds like it's going to be quite the project.....A lot of work to be done there. I think the easiest thing to do is get the same engine that came in the truck, everything will plug in. If not you are going to have your hands full with wiring, electrical.
The LS engine will require extensive electrical modifications to work on your truck and depending on where you live, ditching all the electronics and emissions controls may cause you to fail safety/emissions tests in your state.
I'm not all that worried about emissions tests. Inspection is pretty easy to pass where im at. And I was sliding around some dirt roads and slid a little too far, caught the bumper and it tweaked it pretty good. What kind of modifications would I have to make? I would love to keep it fuel injected.. Would it be better if I took the whole computer and harness from a camaro?
My parents when they where young almost died that way when some younger kid decided to go around a couner into there lane on a gravel road. end of the story they both ended up in the hospital for a long time becuase some people think just becuase they are one country roads they can do what ever they want . Rememmber that next time you go out on some dirt roads. Ive been hit almost 5 times that way . makes me want to shoot there tires out and leave them stranded . If you hurt somone out there by accident beucase your carless there is no cell phones most of the time that work and along time from any help.
Thanks, I know it was stupid and it cost me my pride and joy but could have been a lot more. As Tracy lawarance would say, it's a lessoned learned and I've got about six miles of visibility in all directions, pretty flat and treeless you see. But more importantly for now though I know this could be done because ive seen a c1500 running around here with a duramax in it haha...
Thanks, I know it was stupid and it cost me my pride and joy but could have been a lot more. As Tracy lawarance would say, it's a lesson learned and I've got about six miles of visibility in all directions, pretty flat and treeless you see. But more importantly for now though I know this could be done because ive seen a c1500 running around here with a duramax in it haha...
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
