I have a four inch BDS lift on my cc all terrain. What would you like to know?attachicon.gifimage.jpg
Ur truck looks awesome! After days of researching several small lifts, I decided to go the safe route and ordered the RCX 2.5 leveling kit. This will hopefully hold me over until I decide what lift I really want. I love the stance of your truck and I know BDS is good quality but I really wanted to keep my factory AT wheels for a while. I also have a quicksilver AT but it clearly looks nothing like yours.
Here's my wife's running factory 20's for now & a Rough Country 7" suspension and 1-1/4" body lift riding on 35x12.50 that look like 31's :)
That makes mine with the 6" Pro Comp and 35's look small and inadequate. I like the factory wheels but I think you could easily put some 37's under it.
LOL I think it would clear 37's on factory wheels, but not a custom wheel, and it would need regeared. I didn't realize how much higher it was until I finished it and parked next to one with a 6" Fabtech.
Here is what it looks like with just the 1 1/4" body lift.
How does it look all around with the body lift? Any ugly gaps? Such as I heard the hitch gets a gap between it and the body with a body lift.
No ugly gaps, only place "most" people might even notice it having a body lift is between the frame and bed you can see a puck.
Thanks man. And mine wouldn't be high enough to see the puck from the wheel well I don't think. Mine is only leveled. Want to get it lifted but it'll probably stay like it it for a while suspension lift wise. But It looks like I may do the body lift! Just gotta see about getting it done. Thanks for the pics! Truck looks great!
No problem, the leveling kit and body lift look great together in my opinion, makes it look like a "normal" 4wd truck should look like from the factory. If you were close I could help you out on the parts & install, that's what I do almost daily at my shop. Yes that was a shameless plug sorry :)
I have a bds 4" lift and stock wheels. Spoke to bds about wheels several times. Not sure how it applies to the smaller rims but stock 20's work with the 4" kit. Not sure about anything bigger but no issues with mine.
If anyone has info to the contrary regarding compatible wheel sizes please share as I was told several times the stock 20's would cause no issues. They even gave me optional tire sizes for the stock rims. I will also second the quality of BDS customer service. They were extremely attentive, responsive, helpful, and patient. Always answered emails in detail and never seemed to rush me off the phone. I have no doubt that regardless of a $3,000 kit or a $300 kit the service would be the same.
Any pics of your truck lifted with the stock wheels. I just ordered my truck and want to keep the stock 20s and was also wanting a BDS 4in lift. Does your lift have the rear blocks or replacement leaf springs?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
