That is what my truck had on its DIC.
Oh I would try hand calculating it the next time you go fill up, some members have said that their DICs are off by a MPG or 2
Was your foot off the gas and coasting down hill. ;-) I'm stretching just to get that with 20's and a leveling kit.
Tapatalk via Moto X
I am considering the RC 2.5" kit but also have the 22" wheels on order. Has anyone done this combination with the stock tire size? Any pictures would be appreciated.
Thanks.
Hello guys.. i have just bought a new GMC 2014 1500 regular cab Z71 and I'm going crazy..!! I just can't find the right lift and wheel size and I'm worried about the rubbing issue and car/wheel size ratio.
Find below some of the options that I'm looking at.. if you know some better options I don't mind considering, this car will be my daily driver and I'm not much of an off-roader but I need something with high quality comfort ride.
Bilstein 5100 adjustable leveling shocks with the rear shocks
RC leveling kit 2.5'' front & 1'' in the back
Fox 2.0 Front Coil-Over Shock 0-3'' Lift combined with Fox Rear Shock 0-1'' Lift
285/65/R18
285/70/R17
305/70/R16
so please help me biuld my car, pictures are highly appriciated.
that 13-16mpg on the highway is abysmal. i get 20mpg without trying commuting to work at 65 mph on cruise, going through about 10 miles of 30-50mph towns and stoplights. can get 22mpg without cruise and working the gas. 70 mile round trip. 2wd, all factory. almost 33% decrease doesnt seem right
Edited by mikemjohnson
I installed the Supersprings. Took about 2hrs. Removed tires and mounted. Having power tools would of made the install faster, I used socket wrenches. After install I got about 1 1/2" of lift. The rear end is a tad bit stiffer, not bad at all. I believe as the leafs get some miles on them they will soften a tad. Over all a good purchase. Got some rake back with the 2" level up front and the addition of a even and more stabile ride when towing. To note I used the upper mounting holes for additional lift and went with the medium duty bringing payload to 3000lbs. Not that I would load to that but its there.
The only thing you can see is the bottom of that bracket in front of the rear (front) mud flap.
Tapatalk via Moto X
Edited by anthony2558
Does anyone have a pic of the 2.5 lfront leveling kit and the added 1" block in the back. Just want to see how it looks with a bit of rake
Tapatalk via Moto X
Well I'm jealous, want to buy me a set? Looks great. Got any pics of them under load by chance?
I'll see what I can do. Its been raining like crazy here and don't plan in using the travel trailer till June.
Tapatalk via Moto X
Not to thread jack, but I guess I'm in between the leveled and suspension lift threads from a height perspective. I went with the 2.5" level + 1.5" Body Lift and have a total of $240 in 4"s of lift. Install was easy, retains warranty (at least according to my dealer), and is reversible unlike cutting up the crossmember for a full suspension lift. Can't go wrong with this setup in my opinion.
20140318_194657_RichtoneHDR_zpsn3hz79tl.
20140321_172139_RichtoneHDR_zpsbdq0kk7l.
What Kind of mpgs you seeing?
Thanks.
The pics of my truck with 2.25 readylift level on stock 22's are in the level kit section.. :chevy:
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
