Hi all. I got a 2014 4x4 GMC Sierra I'm looking to lift with a RCX 7" lift. Whats everyones opinion on this kit? I like that it seems like a "taller" kit and it doesn't use knuckles so the front tires wont stick out. I'm probably gonna end up running 35x12.50 on a 18x10 rim.
Thanks
Thanks
Im running the exact setup to the T
I have a pro comp lift on my 14 Highcounty and Have nothing bad to say about it.
Chevy 4
Edited by HighCountry22
dcc0ccd87e5ee9400cdc55d51b5cc699.jpg got the CST 10" KIT installed, finally, I thought my zone 5" rode awesome.... But this kit is flawless, installed atlas soft ride Springs in the back, rides like a caddy. af7d8af9af258d662603845e24758b3a.jpg
  • Like 6
AWESOME! !
I picked up my 2014 Z71 4x4 from 4WheelParts after her lift and new shoes were installed.
After reading so many posts and looking at many more pictures I was a liitle bit worried about how she might look. Would the tires and wheels be to small or two skinny? Would the tires look aggressive enough? Would I lose the smooth ride of the Z71 package? When I showed up to pick up my truck she was parked out front of the shop. I was immediately thrilled. She turned out to be exactly what I had envisioned in my mine for over a year now. After taking her for a drive I found that she handles great and the ride is as smooth as butter. I can not be any happier.
Procomp stage II 6inch lift.
20inch Moto Metal wheels.
Toyo 35 inch AT 2's.
2.43 in the rear.
Next up the Borla Atak exhaust system with black chrome tips. I think ? What do you guys/girls think ?
Edited by Rik2014SilveradoZ71
Sick truck!
Sent from my iPhone 6+
Just got my truck about a month and a half ago had a 2012 Silverado extended cab 6.5 bed with 2.5 level in front and 2" blocks in the rear. Now for this truck im debating between rough country 3.5 without upper control arms or the rough country 2.5 level lift and a 1.5 zone body lift. Do a lot of plowing in the winter so looking for something where I can clear 33s possibly a hair smaller and not really rub. Any help/input would be greatly appreciated!
Just got my truck about a month and a half ago 2015 Silverado 4x4 lt all star edition double cab 6.5 bed, had a 2012 Silverado extended cab 6.5 bed with 2.5 level in front and 2" blocks in the rear. Now for this truck im debating between rough country 3.5 without upper control arms or the rough country 2.5 level lift and a 1.5 zone body lift. Do a lot of plowing in the winter so looking for something where I can clear 33s possibly a hair smaller and not really rub. Any help/input would be greatly appreciated!
I would not suggest a body kit if you do plowing because the bumper brackets have to be modified and everything fits a little differently when you do that. I have a 1.5" Zone body lift on my truck and when I installed my N-Fab light bar, it took a lot of measuring/cutting/grinding to the get the brackets to line up. Just something to think about.
Ok I haven't gotten any of the plow stuff yet going to wait until everything is done lift wise first. So not sure if that's going to make a difference in the difficulty or not
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,588 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
