FINALLY!! After 5 missed delivery dates and constant pushbacks from FOX, we have just recevied our order of FOX 2.0 coilover systems. If you have a current order, it will ship Monday, please be on the lookout for an email update.
If youd like to get your own, please use this link
http://shop.mrtmotorsports.net/fox-racing-shocks/fox-20-performance-series-shocks/98502018fullset/i-3735491.aspx
Have a great weekend.
Hey All, just want to say thanks for everyones posts and information they've added to the forums. So now that I've been contemplating this for a few months and have read over 400+ Pages of Lifts + Tire/Wheel Setups, I think I am set on what I want to get. Just looking for some answers and even just peoples opinions on it. This is on a 2016 1500 LTZ Z71 Crew Cab 5.3L Midnight Edition
I am just confirming that a suspension lift is much safer for the truck than getting even a BDS level. I want a 35'' tire on 4.5 Zone lift, but that's only if lifts are that much safer for your truck than levels.
My ideal setup is the Zone 4.5 Suspension Lift on 35x12.5x20 or 295x65x20 (Thinner so it might not rub), on some Fuel Assault Wheels (http://www.fueloffroad.com/assault-d546-w-18791.htm) with +20 Offset. I know people have ran tires this size with a 4'' BDS without rubbing but they also had +7 more offset from stock rims. Anyone have any thoughts on if it might rub or not? And if those rims would look good on a midnight edition ? I haven't seen anyone with the rims driving around yet.
The tire my heart wants is a Toyo MT, but my brain is telling me to do an RT due to the fact that I will rarely be going off road. I understand it's a truck and I will be taking a huge MPG loss, but the MT's just look much more aggressive than the RT's, which is what I like.
I am also curious about Add A Leaf, Since I am doing the Zone 4.5 Lift, do I need to add it? I am not a fan of the rear being much higher than the front. I like a more leveled look.
I know the Zone Lift pushes the wheels out 1.5 inches, so I will get spacers for the back wheels, but I read somethings about hub centric rings. I am not sure what those would be needed for. If someone could explain that would be awesome.
I also will be doing the Fox Shock Add On if they are better than the Nitro that come with Zone, or would it be better to purchase 4 shocks for all corners? Options?
Last thing, I'm assuming most people do a lot of their mods before their truck is paid off. I know I'll be doing this while I still owe on it, but just hard to swallow the truth. Thanks for reading/helping! Everyone posting in these forums has been a huge help!
So question to all the guys who have a 4inch suspension lift (BDS) with 33 inch tires. How tall is your overall truck now?
Does the whole truck lift up 4inches or just the front and the back by like 2 since the rack?
Sent from my Pixel XL using Tapatalk
i have a 4.5" Zone and I went from about 36.5 front to 42.5 and 39 rear to 41.75
Edited by wildchevys
Not quite sure what you mean by " much safer"
A 2 inch level is way less obtrusive on the truck. If you are talking about doing 3 inch or higher level kit you are angles will be greater it will ride worse and wear out parts quicker.
N
But with any lift kit their will be some cutting involved. Probably not what you wanna here, but it's reality.
I did all the work myself and couldn't believe what I was doing to my truck while I was doing it. But end result is I love the truck 100 times more since I lifted it and would do it over again.
Oh and I had level kit on this one prior to lifting it. If you have the bug to lift it might as well just do it because that feeling won't just go away
So the rear didn't go that much higher. Can I ask what is your height all the way to the shark fin on the top of truck? I want to know if it will under 80 inches or not. Thanks.
I have a 4" Procomp and truck fits into 81" garage opening. Ground to fender well heights 43-3/8" rear, 42-1/2" front, 305/55 20(33")
Edited by CP4
yes I'll check, and I only have a 3" block in the rear which is why the back didn't go up much. I wanted to get rid of any rake
Ok here's a question I've searched for and can't find an answer.
I currently have a 2014 crew cab skyjacker 6" lift but want another 1.5-3" of lift. I've looked at body lifts that's the cheapest way to go but don't want to really.
Can I run UCA's and a 2" spring in the rear and do what I want wit my kit?
Sounds like someone needs a new lift kit. You'll need to look up the installation instructions for your current kit and see if anything had to be hacked up. If so you'll need to fund a new kit that does the same hack. CST makes a real nice 8" kit that can run 37's along with FTS, Coginito and a few others.
I have a 2016 Silverado 1500 Z71 and I want to lift it, I'm looking at Rough Country's 3.5" kit (SKU:175.23) also looking at the Pro Comp 4" kit. (don't have exact model) its about double the price and the reviews on both are up and down on both sides. Any thoughts on which one is the better and why?
Edited by Z71DarkDragon16
BDS 4"... Buy with confidence my friend.
neither.
BDS 4" or Zone 4.5"
The RCX is garbage and procomp is a glorified leveling kit
I have a 2016 Silverado 1500 Z71 and I want to lift it, I'm looking at Rough Country's 3.5" kit (SKU:175.23) also looking at the Pro Comp 4" kit. (don't have exact model) its about double the price and the reviews on both are up and down on both sides. Any thoughts on which one is the better and why?[/size]
The rough country 3.5 lift is a stretched out leveling kit. The 4" pro comp is an actual suspension lift similar to bds and zone. The pro comp is about 3x as much as a the rough country 3.5 at 1600-1700 dollars depending who you buy it from.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,173 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
