3 hours ago, Vblock said:
Not sure if this is the correct place to post or not but I’ve read through a lot of this thread and haven’t seen anything related to my question. For you guys running 35 in tires what engine and gears do you have? I have 33’s but really want 35’s I just don’t wanna put too much stress on the tranny. I have a 2017 Silverado LT Z71 5.3 with 3.42 gears. Will 35’s be too much?
I have a 2015 Silverado, same engine and gears.
The difference in town wasn’t noticeable with the 35” tires and 6” lift. On the the interstate tranny downshifts more for slight grades. The big difference was losing 5mpg . But I knew this going in so not a surprise. The folks with 3:08 gears say they notice a loss of get up a go. I believe you’ll be fine as most of us are. In the future I got plans to re gear to a 4:10 . From what I read and my local shops recommendations that should put less stain on the Powertrain and give back some of the performance. Hope this helps
Yes it does! Do you have a tune? I know it’s not a permanent solution to the bigger tires and the tranny but I have a custom tune so I was wondering if once I do up the tires and get a new custom tune it would help as well till I got a re gear.
Yes I have the edge tuner . It adjusts the speedo for bigger tires, de activated the AFM. I used the edge values for the trans shift points It cleaned up some of the sluggish shifts and downshifts smoother. I have the throttle management as well set at 20%. Also a cold air intake , I’d say is a waste of money but it all works together. A good tuner is a great buy. I recommend the hand held , some complain about dead battery with the ones plugged into the obd port.
I have a diablosport i3 with a custom tune from lew so he tweaks all that stuff for me.
I’ve read good reviews about lew. What lift and tire/ wheel setup are you going to do?
I have 33x12.5 on 20x10s with a -24 offset on a level right now. I wanna do either a 4 or 4.5 lift with 35s. Lift will depend on how much money I wanna spend. It will either be the 4 in BDS or 4.5 zone.
That bds system will put a smile on your face. Amazing how a 35” tire fits those 4” lifts.
3 minutes ago, big papa said:
Zone 4.5"
The ability to keep factory wheels is a big bonus. Very nice truck.
The truck came with ugly 17s.  I bought aftermarket copy 22s.  I love not having crap thrown all over the side of my truck.
Agreed[emoji106]
Sent from my LG-G710 using Tapatalk
On 6/12/2013 at 5:46 PM, plunk77 said:
saw on facebook Rough Country has released its leveling kit and 2.5" lift for the 2014. they look exactly the same as for the previous generation. But, they have a video that shows a new silverado with a 2.5" on it. although its a little low for me, it looks amazing
http://www.roughcountry.com/suspension/4wd-chevy/1500-leveling-lift-kit_1303.php
A shout to plunk77 for starting this thread almost 7 years ago. So many pages of info and great pictures. So glad this thread never died.
Looks great!
i have 275/70r18 K02s on mine.
rides like a slug considering I have the 3.08 gears. You didn’t have to change out your rear shocks for the 6.5 lift? I didn’t think the Bilsteins would be long enough
I got you. When I ordered my truck, I went with the biggest gear ratio they offered at the time. Yes, I contacted Bilstein and they provided me the part number, to order the right rear shock. I went on eBay and ordered it for around $175 shipped. I knew I was going to lift my truck, prior to leveling it, so I went ahead and got the rear shock to allow me to just swap them out.
On 2/22/2020 at 11:35 PM, GrizzTheCat said:
Please help. My knowledge on lifts is very limited. Would you recommend a 4.5 inch lift or a 6 inch lift for mine? I have Bilstein 5100s on it, would I be able to keep them?
hey man whats the set up you have on your truck in this picture. i like it
-275/70r18 BFG K02 tires
-Bilstein 5100s 2.5 inch struts and matching rear shocks
-I had the OE wheels painted as close to the shade of gray on body paint
-I debadged the truck minus tailgate Bow tie
-Added black Z71 badges to doors and grille
-Bought OE illuminated bow tie package which comes with illuminated grille bow tie and regular black for tailgate
-I’ve had 2 front end collisions so I had body shop swap the lower chrome mustache to the black one
-Took off the lower valance 2inch air dam
-20 percent window tint in front to match factory rears
-Windshield tint bra
-Added an OE drivers grab handle
-Put on 4 inch black carbon running boards from Tyger
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
