Awesome info guys. Looking at the Zone 6.5 on 35s. I have a 5.3 but the regearing seems like a big chunk of change. As stated above I'm not racing anyone so that slower speed doesn't really affect me to much. So as for the people who didn't regear and are running 35s, you guys don't have any complaints?
Edited by NorEaster
From what I’ve heard guys with a 3:08 gears say their trucks seem a lot slower. But with 3:42 gears you’ll be fine. I got a hand held programmer , cold air intake , free flow exhaust and problem solved.
16 hours ago, NorEaster said:
Anyone here running 35s in a 5.3 without regearing?
Yes, you really notice right after they are installed, then you forget.  Not like when I put 35s on my Jepp Rubi.
  • Like 3
I'd be more worried about rubbing than gears
Take a look...
Tell me that's not going to rub.
Edited by dieselfan1
21 hours ago, EDL said:
Looking at the various lifts in the 4"-4.5" range, they all seem to require either cutting out the crossmember completely, or some form of cutting it.  Doesn't that weaken the heck out of the frame?
Not enough cut to worry about.
I drove my 5.3 with 22x12’s on basically 35’s for about a year and a half. You definitely feel the difference in the beginning but it’s not the end of the world.
  • 3 weeks later...
On 4/30/2020 at 6:38 PM, ZX14R BUSA KILLER said:
What are the stats on this one, Busa killer?
On 8/1/2016 at 10:26 PM, FueledGMC said:
I've followed this forum for a while to determine what setup to go with. Here's what a came up with so far....
Thanks all for sharing! Helped tremendously
2015 GMC Sierra Crew SLT 4x4
Fuel Assault Wheels 18 x 9"
BFG TA KO2s 285x65x18
(Dropped from 20s to 18s to showcase the KO2s side tread)
3.5 Rough Country Lift
Model:27820
(I will admit, there is a very minor rub on the front when I cut all the way to one side or the other, but otherwise all is fine.)
Magnaflow Exhaust - Dualed
post-161042-0-70557100-1470107844_thumb.jpgpost-161042-0-03539600-1470107868_thumb.jpgpost-161042-0-83829100-1470107894_thumb.jpgpost-161042-0-20743500-1470107949_thumb.jpg
So here i am 4 years later and countless front end issues due to the bad angles with the Rough Country lift. I HIGHLY RECOMMEND NOT going with the 27820 3.5" lift by Rough Country. way too many issues. looking at the BDS 4" now.
  • Sad 1
On 4/10/2020 at 6:24 AM, big papa said:
All day, 35s on 22s
Very nice! What are the specs on those tires and how much of a lift do you have?
Zone 4.5'' lift, 35s on 22s
Guess I'll add mine ... 7" rough country with full struts not spacers and 22x10 fuels -24 offset ... 35x12.50s .. rubs stock bumper in reverse when turning and barely kisses back of fender well under same situation ( already pulled the front bumper for a DV8 offroad one and gonna do normal mod soon)
2018 Chevy Silverado sitting on a 9.5" Suspension Lift, 3" Body Lift, and ridding on 20" KMC DEMODOG Wheels wrapped with 37" Toyo Open Country RT's!!!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
