I came across a new 4” lift from Belltech that’s very tempting. I’m wanting to replace my Ranchos, do away with my leveling spacers, and gain a little more height. The Belltech front shocks are adjustable for 3-4” of lift. The kit comes with upper control arms, diff drop spacers, diff skid plate, rear lift blocks and rear shocks. Who wants to be the first to try it out and give a review?
Edited by HoosierZ
RIP tie rods and lower ball joints
I really don't like this kit. Not really a lift if you ask me. Now they have a 7" kit that's about $1800 that's a true lift kit. It looks suspiciously like a McGaughys.
Belltech, just like McGaughys has been making lowering kits for trucks since the 80's. So they know what they are doing . Up down what's the difference. It's quality parts.
Sent from my Pixel 3 using Tapatalk
It’s basically the same as the Readylift 4” kit with adjustable height struts instead of spacers and people seem to like that kit. If I do get it, I’ll probably set the struts to 3” or 3-1/2”. I would assume after 30+ years in the aftermarket suspension business that Belltech knows what they’re doing.
I noticed that they have a 7-9 kit.. It looks exactly like the 7-9 McGaughys piece for piece
The only “good” way to get anything over 2.5” is with a drop bracket because it maintains the suspension geometry. Otherwise lower ball joints and tie rods wear out extremely fast and the ride sucks because you’re riding on the UCA droop stops
  • 3 weeks later...
My 4" leveling kit had huge rubbing issues with 33" tires.  I'm looking at getting a new sierra but would like to do a ~6" lift.  Which one seems best?
I'm having a hard time, picking a BDS 6" or zone 6.5" lift. I have a 2018, 1500, Redline, 6.2, with stamped UCA. I would really like to run the factory 20" with 35s for a while.
I really want to go with the BDS lift, but the extra .5" for $600-$800 less is a hard pill to swallow. Could I run a 1/2 front strut spacer with the BDS lift? Maybe something like this ( https://www.amazon.com/MotoFab-Lifts-CH-5TM-Leveling-Pickup/dp/B017WN9DIC )? Also does the BDS 6" really only lift 6"? I have read a few times that the BDS 4" lift does run tall, but does that translate over to the 6" as well?
I did reach out to BDS/fox and they just said "I don't recommend adding a spacer on top of this kit"
Thanks to anyone that can help.
I've been running an under strut level with a zone 4.5" for a few years now without any issue. I had a .75" under there and swapped it to a 1.5" about a year ago to clear 295/65r20 on factory wheels. I don't know what it'd do with the 6" kit though. As far as I know the brackets are the same for both kits, only the spacers are different, so you may not want to push the 6" kit any taller.
I went with a 4” BDS coilover and 35” Toyos on my 2018 Sierra, haven’t noticed any rubbing. Shipped with a bad coilover so I have a clunk until the new one comes in though, FYI.
Another quick question for everyone, BDS 6" VS McGaughys 7"-9"?
I like the warranty for BDS, and it seems like a lot more people run the BDS kit, VS the McGaughys, but the option of getting one lift and able to go from 7-9 I think is a huge benefit, I'm just am not having a lot of luck finding reviews/posts about McGaughys lifts.
I can get a BDS 6", Fox 2.0 performance shocks, and add a leaf for $1,850 shipped.
or a McGaughys 7-9" Premium Silver, for around $1,915, shipped.
any one have any pro or cons for them?
Thanks.
Thanks.
They’re both good kits, just depends what you want. The fox is likely better than the shocks that come with the mcgaughy’s kit, but the mcgaughy’s kit gives you more lift. Not everyone is after a 9” lift so the 6” kit fits the bill
Thanks.
The McGaughys because you can go to 9". That how I roll.
Once you lift it you'll wish you went higher. Always happens.
I'm already thinking about a 1.5" body lift and bigger tires and I just lifted mine in April 2020.9d6c061e913169d33504fec5a7240d34.jpg
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
