I was tired of buying these knock off brand rigid and hearing that all brands are the same. So i sucked it up and spend the money on Rigid and my god, there is a true difference in quality and craftsmanship. My rigid reverse lights are so bright that even when i back up during the day i see people covering there eyes.
Did I miss something, are you talking about a set of Rigid Flush mount cubes, or does Rigid now make LED Brake/Reverse/Turn bulbs?
Got my interest up too! :drool:
Ok, cool! Thank you!!!!
I have a 2017 LTZ, let me know about the tail lights, will you need resistors?
Resistors are needed for the tail/brake, so far.
If you want some mind blowing backup lights try these: They are simply OUTSTANDING!
JDM ASTAR 800 lumens Extremely Bright Error Free 921 912 PX Chipsets LED Bulbs For Backup Reverse Lights, Xenon White
Sorry about the confusion, the rigid lights i have installed are just added reverse lights.
Anyone here have problems with installing LED bulbs for the rear turn signal/brake lights? I bought some bulbs on eBay and they work fine, nice and bright which is what I wanted, but after installing them and the resistors on all four, with the parking lights on, my brake lights don't work. Turn signals work fine with the parking lights on or off and as long as the parking lights are off, the brake lights work fine AND there's no hyper flash. I couldn't figure it out yesterday. Drove me nuts!! I ended up removing the resistors for now and they work just fine, everything is normal except now I have the hyper flash.
Any ideas?? :help:
For anyone who is interested in finding the old school incandescent nearly impossible to find 7444LL brake light bulb, the GM Parts number is 13591403. This can be found at most GM dealerships and various online vendors. I started a quest to find a 7444LL bulb at the local auto parts stores; NAPA, O'Reilly's, Auto Zone, locally owned stores, etc. to no avail. They all sold only the the 7443LL which is a less bright than the 7444LL.
Just swap out the original bulbs to these, that's it?
Yes, 2 torex screws and you have to pull kinda hard to pop the housing out. Swap the bulbs and enjoy. They are very bright.
I did put some dielectric grease on the bulb before inserting.
Edited by No Tyme
Can someone recommend some good long lasting LED bulbs for low beam and high beam? I was looking at these but im not crazy about the 7200k color. Also, i want
them to fit into stock housing with no mods needed! Thanks.
https://www.superbrightleds.com/moreinfo/low-beam-headlight-bulb/led-headlight-kit-h11-led-headlight-bulbs-conversion-kit-with-compact-heat-sink/3924/8559/#tab/Specifications
I just bought some of these off of eBay, made an offer for $15 (was asking $19.99).
eBay auction item# 332341672755
Be sure to let us know what you think of them!
I just our bps lights in my 14 Silverado. They are not coming on right away. Even when manually selecting them. Almost like they need a capacitor to store up enough power. I have not had this issue with past led or hid setups. They come on a minute later. Also when I park they shut off. Any advice? I have read through a lot of their thread and don't see anything related to this.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
