The HD relay plus capcitor kit should solve that. Put the capacitor kit between the stock headlight bulb plug and the relay and make sure the capcitor kit has a good ground.
I do have the relay harness, I bought the Sierra spec kit. The capacitor is in-line before the harness. Like I said, it works perfect at night but not during the day with the lower voltage that the DRL provides. I'll re-check the ground for the capacitor.
I know for mine sobe the Drl's work when I put it in drive. I have an slt with a fxr retro I did.
Sent from my SAMSUNG-SM-N910A using Tapatalk
They also come on when I remote start the truck and it's just sitting there.
The adjuster consists of a ball and socket joint mounted to a gearset that allowed you to adjust it.
Take the headlight out and you will find that the adjuster is removable with a quarter turn counter clockwise. You will see the arm with the ball on it. Extend it out fully by turning the adjuster and insert it back into the headlight, feeling it click back into the socket joint. Carefully adjust it in slightly to make room for you to reinstall the adjusted into the headlight housing. Adjust carefully or you will pop it out again, but no lasting damage should have been done
OK danger. Here's my problem. I don't know how but half of my teeth on the adjuster is wore smooth off. Now. I'm screwed. Tore the front of my truck apart and can't fix it. Damn
Try flipping the connector from the capacitor link that connects to the OEM input adapter that used to plug into your stock bulb. I drew it out and it's attached. I thought it would be easier to show you what I mean.
I just used some glue to hold the nuts and put all 4 bolts in to the brackets. Upgraded the size of the bolt and used all stainless. Also used larger stainless to hold the brackets to the housing, the same when I did it before the fast brackets in post 901.
Yup, I used stainless too.
Either your capacitor is bad, you have a bad ground, or the harness is backwards. I just tested mine and my DRL's work perfectly with the capacitor as it came. This should be what you have below. Refer to the second picture on swapping pins in the plug if that is indeed the problem.
http://www.theretrofitsource.com/components/harnesses/capacitor-relay-harness-link.html#.VckiTKgVhBc
This is all I had to do is flip the capacitor harness like you described. It works perfect now. Thanks everyone!
Ok guys. Got my fxr's adjusted the best I could out here on vacation in Colorado but I noticed one thing. I have the height of my cutoff maxed out and it's not high enough. I had a real issue getting everything stuffed in behind the cap and sealed up correctly. I think the new D2S igniters housings are too big because I had to modify the cap to get them to fit and it is really snug. Went through hell trying to get the igniter on the bulb to twist it on. Now it looks as though the igniter wire is rubbing it too. I just need to raise it up about a foot more to get it where I need it. Dang it. Any suggestions to get the height I'm looking for?
Edited by 440hsp
IMG 4051
Im really confused by the wire in the photo. Its coming from the headlight of a morimoto HID kit.
This is the driver's side headlight and there seems to be no problems with the HIDs functioning. Did I do something wrong ?
I don't have morimotos but looks like an end that plugs into a ballast or error cancellers
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
If everything is working right, don't question it [emoji1]
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
