I just went and unplugged the relay from the harness and plugged it back in. Everything works fine now. Weird? bad connection maybe?
While changing bulbs and redoing my headlight caps to a better seal I decided to increase the housings availability to breathe. I'm one of the guys who's completely stock lights had mild condensation GM said was normal. I noticed TRS sells and recommends Gore-Tex patches so I picked up some goretex and drilled the high beam caps with two large holes and covered them with the patches. No moisture gets in, but the housings breathe better now. I figured the high beam caps would be easily fixed if there is an issue. I also put another set of holes up high on the side of the housing.
Could be. I like these relays for critical items that need to be water resistant:
http://www.amazon.com/gp/product/B003TEO9GU?psc=1&redirect=true&ref_=oh_aui_search_detailpage
http://www.amazon.com/gp/product/B000VU9D0C?psc=1&redirect=true&ref_=oh_aui_search_detailpage
Just installed and tested out my new bulbs: Osram 66240 CBI's. They work great and are PURE white with my 35W morimoto ballasts. Pricey, but I think they were worth it. I did run into a ricer with a PNP HID kit and let's just say my FX-R's bi-xenons on high combined with Halogen high beams won. The light output in f'ing insane with all four linked together.
Im in the middle of the installing the morimoto silverado spec kit on a 2015 silverado and Im towards the end of this project and am confused as ever..
Does one of the OEM plugs not get used comming from the headlights? It all seems very straight forward and then i end up with this plug at the end with no where for it to go. Any help would be much appreciated. THanks.
Correct, only one factory headlight plug is used to trigger the relay. The other you can tuck somewhere in the housing.
By the way, do you have projector and housings or reflector housings? Also, what have you done with the headlight covers? Did you somehow extend them out because when I attempted to put the cover on, there wasn't enough room with the HID bulb and plug for the cover to go back on.
I have the projectors for the low beams which are the ones I'm currently replacing. The directions say to drill a hole in the cover for the wires to pull through. Did you have to do that or are you saying that even after drilling in the covers the bulbs still poked through?
That is correct. At least on my truck, I would have needed to extend out the covers. I scrapped the project until I can figure out what to do with the covers.
Edited by Lbsigman
Well I went on ahead with drilling out one of the covers anb you were absolutly correct. The light plug stuck trait out of the hole and you couldnt seal anything back up. I decided to drop back and punt as well. Im hopeing i can return the kit considering it was for a silverado and it doesnt fit like the instructions say. I really wanted the lights to work. I will be putting the silver stars in i guess like I probably should have anyways. Thank you for the help.
Yup it's a total let down. I was super aggravated over it and luckily I only drilled one cover. I ended up keeping the kit but I need to figure out what to do with it. I do have 2 spare covers to play around with so maybe in the future I will try again.
I had a friend run into the same problem with his Chevy Volt projector light. He ended up buying some black abs tubing that was close to the same size as his projector cap and glueing it on as an extender after he drilled out the back. It didn't look bad after he was done with it.
Where did you find spare covers at? I patched mine with a plastic repair kit but It looks a little rigged up. I had rather have back to normal until I figure a better option out.
I ordered 2 new covers from GM Parts Direct. Not cheap for what they are. After shipping, the total was like $56 for the pair. Part Number: 23215569
Having a bit of trouble with a TRS/Morimoto HID install.
Had a 2014 Sierra SLT that the following system was being used in:
9006: Morimoto Elite HID System
-2 x AMP: Morimoto 3Five DSP
-2 x 9006: 3Five 4300K $0.00
-2 x Canbus: 9006 $0.00
System was removed from the 2014 and placed in a 2015 Sierra SLT today. I can't for the life of me get the lights to work. Fuse looks good and after speaking with TRS I hit my ground contacts with sandpaper to remove some paint and ensure a good connection.
Any ideas? Did anything change from 2014 - 2015 that would prevent the system above from working?
Thanks in advance.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
