I run an auxiliary cooler on mine. I installed it under the cab, in the return line to the trans, and it has a fan on it that runs constantly. I also have the superior thermal delete installed. I rarely see trans temps go over 170 anymore (usually in summer stop and go traffic or towing). Most of the time they are 135-150 once all is at operating temp. In single digit ambient temps it takes a while to get much temp in it, but it will eventually get into the 120's. No issues, and over 120k miles on this transmission so far, original fluid to this unit still looks and smells new.
So my third radiator is leaking. These things aren't exactly easy to replace, and I'm sick of doing it.
Does anyone make a good radiator to put in them, that won't start leaking in a year?
Every one I've had ends up leaking where the tanks are crimped on. My current one has been leaking for a year now, I just fill it with water every couple of days, or couple hundred miles, whichever comes sooner. And I'm not buying cheap ones. Both of the replacements came from NAPA. I could warranty this one too, but am ready to spend more money if I can get a quality unit.
Thanks
HD at the moment, are kinda their own deal. How LTZ sells on those vs on 1500, there is a difference.
They are merging most of the mid trims on 1500. LT, RST and LTZ are replaced by one trim, Silverado. LT and RST are a BIG portion of sales.
Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered. So expect to see things like the tech package for example, and memory seats. And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will. The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.
Here is the Trail Boss interior. Memory seats and Super Cruise are present. All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen. You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
