2nd link isn't working. But the first link is what the lower spacer is supposed to look like. Looking up the 1303 kit in the second link I saw is the 2.5" kit so maybe your talking about the top strut spacer? It's kind of like a triangle with rounded sides more or less.
Not sure why the link did not work in my original post but it seems to be working in the quote on your post. I am not at all concerned with the upper strut spacer I fully expected that because that is one of the main differences between the 2" and the 2.5" leveling kit. However, if you look closely at the two different kits you will notice that the lower strut spacer is different. The lower strut spacer pictured with the 2.5" kit has a constant thickness where as the lower strut spacer pictured with the 2" kit has a variable thickness.
The one you received just looks to be maybe an older style or design. What does the materials feel like? The ones you expected isn't plastic, but feels kind of like a plastic. As said, it looks like it does the same thing and the fitment guide for it says it fits from 07-present 1500s so it should fit. Maybe someone sent you an older kit.
I agree with SouthernSilveradoGuy85. I believe I received an older style spacer. The material does feel like a plastic but I know from reading other posts in this thread that it is some type of glass resin composite. I will be calling Rough Country tomorrow to see what they have to say. Hopefully their literature is out of date and not my kit.
The first link in your message is to the 2" kit. The second link is to the 2.5" kit. Did they send you the wrong kit?
They stick out maybe a quarter inch. I have fuel maverick 20 wheels with +14 offset. No wheel spacers. Lift is a 2.5 Rough Country front only . 1af906e391628974ab1c87be8ebc056f.jpg50a7536706c5c480a8ab67877c9aa116.jpg7c2e731cb990e9a6ac802a842f366df4.jpg
How tall is the wheel well now up front? I want to do a larger lift on my truck but have a feeling I may do something like this. It's simpler and still looks great.
Hello ladies and gents,
I recently got an RC level and I tried installing it with help from a friend, but we ran into a problem.
The aft strut bolt hole sits directly below my front driveshafts. I can post pics of necessary but does anyone know what I can do about it without removing the upper ball joint entirely?
I ended up removing the ball joint nut completely and putting the new bolt in from the top so I wouldn't have to worry about it ribbing on the shaft.
Click on the link below for pictures.
"I had the same issue, one of the bolts would hit the CV shaft if I installed it with the head of the bolt on the bottom per the instructions from Rough Country.
With the upper ball joint and steering linkage ball joint disconnected I was able to tilt the hub assembly enough to get the CV shaft out of the way and then put the bolts in with the head on the top side and nuts on the bottom. Here are some pics.
http://www.gm-trucks.com/forums/topic/153363-2014-leveling-kits/?p=1505852
Edited by 15LTZZ71
Here is mine 3" front and 2 1/2 rear block which gives it 1.25 of lift in the back. It has a very slight rake. Not sure how much. post-135776-0-88526500-1415339081_thumb.jpg
No leveling kits for the 2015 Denali 1500.
After speaking to Rough Country and BDS Suspension, a leveling kit for the 2015 Sierra 1500 Denali is a NO-GO. They said the magnetic ride suspension measures the vehicle rake and a leveling kit would throw it out of whack.
They said to try back after the new year and maybe they will have figured it out. Maybe will require reprogramming of the mag ride?
I'm kind of bummed about this. My truck should be here in two weeks and that was one of the first things I planned on doing. I'm very much looking forward to the mag ride though. We'll see....
I leveled the front with a 3" kit from CCm Offroad (The kit I used fit 2007-2014), I also have air bags in the back I tow a trailer and didn't want the back to sag. the tires are cooper neon ltz 305/55r20
I also painted the center caps of the rims to match the rims. De badges and tinted the windows.
Anyone know if a 33x12.50x20 toyo open country rt will fit with a leveling kit without rubbing
That is exactly what I am running. I have a 2.25" level. I don't rub.
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
