Mike 1220. Been following you a while now. I was able to fit 34 inch tires with a level on my truck.
Yea but only if they are a 275/65/20 from what I have seen. Any wider and you will rub. I am planning on getting a 4" lift this summer along with 34.5" Nitto trail grapplers and 22x9.5" Fuel Mavericks or I will do a 295/65/20 Toyo M/T on a 20x9 w/ 0 offset. Just a bit taller than a level with 34s without putting you in the clouds like a 6" with 35s. Its a happy median for me.
Mike I have 285 55 22s no rub
On a level kit only? What are the manufacture specs on those tires? I am looking at the Nito Trail Graps that are spec'd at 34.5x12.05
If I can fit it without a 4" lift then I may get the rims and tires sooner. Of course it will still have to wait till the summer unless I can get enough money during the winter holidays, but doubt that will happen since I am already planning to get headers around Christmas
EDIT: Nevermind. I just realized that you have Nitto Terra Graps. I may end up with at least the rims and tires sooner than I expected during the summer. I may have to run a small spacer to keep the rims from colliding with the UCA since it has 6.25" of backspace though. But thats no big deal for a month or 2
Edited by Mike1220
I hit my camburg UCAs at full lock. that all it rubs on. I'm guessing spacers could fix that
Thank you good sir! I just might be getting these tires sooner than expected :) I wasn't expecting it till late summer, but now it may be late winter or early summer. All depends on the finances and whether or not I do headers this winter!
Here are a few more pics on the street with the truck on level ground. Let me know if you would like more pics and I'll get them for you. I received a lot of help from this forum and I want to return the favor haha.
Thanks! This was the shot I was looking for.
I read through the leveling forums and saw one person tried 295/70R18, has anyone else tried this size? Would these rub? Im looking to get the rough country 2.5" lift and use my stock 18" rims.
This man also did the work on my headlights, I can definitely vouch for his work. :thumbs:
I also ran across something yesterday you guys might find interesting. I saw someone run 35's on a single 2" leveling kit with almost 0 rubbing issues so he claims. Anyone else try this setup? (forgive me if this is old news, haven't had time to browse the forum lately)
did anyone ever follow up on this? i'm sure trimming was involved.. just curious how much...
20x10 -12 Fuel Mav
33x12.50 Nitto Trl
2.5 R/C
post-136138-0-89337100-1416022803_thumb.jpg post-136138-0-75150600-1416023179_thumb.jpg
slight rub.
What do you guys think? what else should I do? new to the forum. Thanks.
Nice truck man. I'd say color matched handles and some debadging and done. Looks damn good. Welcome to the forum.
