So it's just getting the right person to install it? Going to have to ask around here, i have no idea who to go to.
So leaving the 2" rear block out of the 2.5" leveling kit doesn't hurt anything?
Have another question, why go spacers like RC if you can get Rancho quicklift loaded or Bilstien 5100?
Probably because Rancho says the quicklift loaded won't fit a z71 and the bilstein 5100's arent available yet. Me personally I'm trying to hold out for the 5100's but Bilstein is now saying January availability but as everyone knows it was Oct then Nov now Jan so who knows.
Edited by never_rested_24-7
hey guys,
Sorry to be a johnny come lately. I have had my 2015 2500 HD for 2 weeks now. I am also looking to level out the front end.
I have not seen a lot on the 2500 HD front lift and I have the Z71 Rancho package.
Are there any recomendations on a leveling kit for this truck. I think a kit that includes new upper control arms is probably the right way to go.
I was surprised to not see Rancho as I am looking at a lot of kits.
Don
http://www.gorancho.com/products/leveling-systems/quicklift-7000mt-leveling-system
So this one will only fit the non z71 SLTs? If so that sucks. Might hold out as well, guess the spacer route worries me a bit.
Awesome, it will be awhile before i can get some savings together for a kit and installation. Likely by that time Bilstein should have their 2014 5100 series adjustable out i would think. Though if i went this route i wouldn't be putting in a rear spacer, so 2.5 in the front my not be required. Another question is this, replacing the front shocks/struts would you not go ahead and replace the back as well? Or can you leave the back stock and it would be okay?
I also talk to a buddy of mine who had a 2" spacer on his Sierra he had, he put that truck through hell with 265,000 miles on it. Replaced the ball joints at 115,000 and replaced the transmission at 220,000 IIRC. So he didn't really have any problems.
Sorry about the constant batter of questions, trucks are new to me. Well any form of mechanics in general. If we were talking Computers or Guns it wouldn't be such a foreign subject as those have been my hobbies for years.
Finally got my new wheels installed..
20x9 Fuel Maverick (+20)
  • Like 5
2.5" Rough Country leveling kitattachicon.gifImageUploadedByTapatalk1416793309.652235.jpg
how far do those stick out? I'm looking to upgrade my rims this summer and am considering this size and offset. Still not sure what I want to do though. IF you could post a pic with how far they stick out it would help me greatly!
I went to the dealer tonight and took a look at some of their lifted trucks. They have a bunch of trucks with 6" of lift on 35"s and man, they look good. But, I need to be able to park in the garage and I don't want to get 12MPG. They had a truck with a 2" level and 305/55-20s (33.4"x12.4") on aftermarket wheels. Here's a photo comparison to stock height.
Now, what I'm wanting to do to a Z71 is run a RC 2.5" level kit with the 2" rear blocks on factory 22" wheels and 33x12.50 Toyo M/Ts with 1" spacers. From my research it should work out about perfect. What do you guys think?
Edited by AndrewGS
Not sure I would even consider buying a dealer lifted truck only because you end up paying more for the lift and all than if you had it done on your own. Plus just more that's financed. The only good thing would be that the lift wouldn't void any warranty, but I've also read where some people just get a dealer to install a lift or level of their choice.
Plus personally I'm picky on things so I would rather have the ability to choose which lift, rims and tires I want.
Yeah, I'd have to go over everything with the aftermarket people first. I know what I want and if they can give it to me for a reasonable price, recalibrate the speedo and warranty it then I'll put it into the loan. If they try to screw with me on pricing then I can always just save up and do it myself. I'd also be looking at the GM-Borla exhaust and AMP Research steps.
I want to see this when you do it! I'm thinking about same thing!
Sent from my XT1096 using Tapatalk 2
    • I use Amsoil's OE line of motor oil (5W20) in our 19 Hyundai Santa Fe. I noticed today on the web site it now says (47% more wear protection1 than required by the GM dexos1 Gen 2 specification). Maybe I  missed it but I don't think so.
    • The amount of storage in the rear seat area is huge. You can keep all your cycle gear dry and clean back there
    • Truck in fluid changes and investigate subtle shudder at cruising speeds.  Told them it felt like my ‘14’s shudder when AFM kicked in.   Dealer #1 :  You need a new torque converter.   6 weeks later, after causing other damages to my truck, I get the truck back.  Same shudder exists. New, more violent shifts and vibrations at low speed.  After choice words and a few more weeks of waiting for them to replace my running boards supports, I move on to another Dealer.   Dealer #2:  The cruising speed shudder is DFM.  (I didn’t realize truck had it.) The TCM/ECM needs updates.  Updates will solve all vibration issues.   They perform updates, truck seemed ok in lot.  Not a mile down the road, SERVICE BRAKE PAD MONITOR. Dealer #1 stated brakes were at 4mm.   took truck back to Dealer #2, rear brakes at 2mm and less than 1mm.     New pads/rotors on rear, new pads up front.   truck seems good. Toggle through menus, brake monitor system is disabled.  Huh?  Why? Turn that sucker on : SERVICE BRAKE SYSTEM!     will not reset manually, automatically, or even after pulling negative bat cable for 30min.     Could the TCM/ECM updates the culprit?    A torque converter diagnosis for a “normal” shudder and now I’m thousands in the hole and the truck still isn’t right!  Beyond pissed.
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
