I too am wondering what the best combination (level and largest tires possible with minor to no rub) for the stock black 22" wheels on the rally editions. Thanks!
I'm planning on going with the Bilstein 5100 adjustable struts with a nitto terra grappler g2 285/50/22
I have contacs at my local NTB, after work I'm going to stop by and see what they say, they have a 285/70 17 tire in stock, he wants to look and see if it will fit for me...
I feel like you won't have any trouble I just put 285/70/17 tires on mine yesterday with a 2" level and have plenty of room the 1.5" should be more then enough.
For anyone interested in 5100's they do compress your coil more and it will cause premature wear of your coils. I had them on my old truck and prior to selling it I put new coils on. My coils I had been using with 5100's were over an inch shorter than the new coils. This is why down the road I will most likely go with rancho quick lifts and a block in the rear.
Camber definitely gets affected you can visually see it with spacer levels. The problem is that "spec" is a wide range and as long as it shows green on the computer they won't touch it.
Edit. I see your camber is negative that's odd I would have assumed positive.
Yeah,
Very minimally to red flag it. I doubt every truck can be set to the same exact parameters. Even if set perfectly, I doubt we could tell as drivers. Lol
The good thing is that it is done!
I find that the 2" level makes the truck look nose high even the the wheel wells measure to be level. 1.5" I think will be perfect, it will have the same rake as a 2.5" level that comes with a block for the rear.
I have a Zone 2" level sitting in the box here. Debating installing it and swapping out the rear block for a 2" block.
I am also tempted to say eff it and return the Zone 2" and not touch anything at all.
My vote goes to installing it. These trucks look so much better leveled IMO
The rancho quicklifts work the exact same way, the spring perch is just not adjustable. Did you actually measure your oem coils before and after bilstein use to see if they had lost some spring rate or gotten smaller?
I have a 1.5" leveling kit on order and would like to know if it's possible to install it without having to remove everything. The leveling block goes on the 2 bolts on the bottom of the strut.
Thanks for the help
Thanks for the help
You'll definitely have to loosen the sway bar, the ball joint and the top of the strut, you might have to loosen the steering linkage.
Thanks for the help
All you have to do is loosen the sway bar bolts. You will be able to pry the control arm down enough. I did my RCX 2" this week and it was pretty easy. No need to touch ball joint, tie rod or upper strut bolts. If you undo both sides before you attempt to install the blocks that will help as the sway bar is connecting both lower control arms.
Love the look of your truck BTW. They have to be the best factory wheels GM has ever come up with.
Edited by K2jer
So I installed my MotoFab 1.5 level kit, now to see of I can fit 285/70 17 tires on factory wheels under there...
I've noticed a noise coming from my CV joints. At full lock, going pretty slow is sounds like a rubbing/clicking sound. It's very light/faint. Had the GF get in it and turn the wheel and move the truck forward and to the rear, turned at full lock both ways and the sound comes from the CV joints. Not sure of its normal, it's been to cold to have the windows down to hear anything until recently.
I think that's my problem, I don't want to level it, I'd just want to lift it 2-3 inches with a full on kit which will cost $$$.
Then after I think about it I realize I don't want to spend that kind of money and I'm back to just leaving it stock lol.
Ah well. I'll keep researching.
Didn't work for me on my 2015 z71.
    btm
    btm
  • Who's Online   5 Members, 0 Anonymous, 1,472 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
