2" Rough Country front level, stock rear, Toyo Open Country ATii eXtreme 10-ply 295/55/R20s, stands F-39.00 and R-39.75" from ground up to lower lip of fender trim.
Edited by rewillia
Hey guys I have a 2014 black gmc sierra all terrain crew cab in which just installed a rough country front leveling kit (2 inch). Just want to know what the tallest and widest tire I can install without any rubbing? I have the stock 20 inch rims on. Thanks!
You can run
33s
An some people are running 35s but believe that is with the 2.5.
I'm running 33s hate the tire but love the look of her right now. 5c202cd2944a60eef29cab0c7333f000.jpg has a lean due too the parking lot lol
My Current Setup,2014 Silverado 2LT Z71,RCX 2.5 Level Kit,NittoTerra 33x12.50R20Lt's,Fuel - Octane D509 20x9 -12 Offset,All Chrome Plasti-Diped
My Up Coming Mod's,McGhauphy's 7"-9" Economy Lift Kit,Federal Couragia M/T's 35x12.50R20Lt's,OEM Tow Mirror's,Bushwaker OE Fender Flairs,Gtr Lighting Led Conversion Kit's 2,200 Lumen(High,Low,Fog),Black Spyder Venom Bull Bar,Iron Cross HD Step's.
Edited by 2014Sandylifted
295/55/20 is popular on stock 20s. I wouldn't be afraid of 305/55's or 33x12.50 on stock wheels either. Offset plays a major rule
Well, I have gone and pulled out my level kit. I don't know what it was but it rode like crap. Maybe its because my ranchos have 74,000km on them and they're just too dead to handle that extra stress from the leveling block. I am either going to buy a set of used black stock shocks or upgrade to rancho quick lifts.
I run 40 psi in my 265 65 18 SR-A. I took out my stock springs at 400 miles and put in rancho quick lifts. The ride is even more comfortable now. Get yourself some Ranchos. Or if you want stock struts you can have mine at a very reasonable price.
Thanks guys i'm running 275 60 20 right now but want to put on 305 55 20 bfg all terrain but just not sure if they will rub?
Not going to be the diameter you need to worry about. It will be the width and offset of your rims. They're going to rub for sure without a level, and most likely with a level.
lol fair point, i imagine it would look like it was squatting. Just glancing at mine sometimes looks like the front end is higher than the rear. Really depends on the amount of factory rake you have. I thought i would see a noticeable amount of rake with 1", but i can hardly tell honestly.
Yeah I realized I essentially want a proper 2" or so lift. Not just a level. I like the way the truck is, i just want it to be a bit higher.
Maybe quick lifts in front and 2" blocks in the rear.
Edited by Dropsix
295s will also rub on stock wheels
Edited by CptMcSaug
2WD Bilstein 5100's all around. Front set at 2nd highest setting, with a 1" lower shock spacer from E-bay. Rear has a 2" block in place of stock block.
Wheels are Black Rhino Tanay 20x9+12 with BFG KO2's in 275/65.
Rides more firm than stock for sure, but still rides good. Stiff, and tight I guess, rides like a Truck!
Also have a Diablo tuner and Airaid CAI, runs good.
Edited by Nolasaintz
  • Like 4
Nice truck! I still cant decide if I want to paint my fenders. Your's looks really good. Im just thinking once I paint my bumpers white it would be too much with the fenders as well.
Like those black rhinos, really complements the truck.
Awesome truck... can u take a pick frome the front and rear please. ..
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
