How did the spacers fit, stud wish is there enough left to safely tighten the lugs. Also I can't seem to find anything but 2" spacers on the rough country website.
I have a 2015 Sierra 1500 All Terrain with 2" level (stock 1.5" rear blocks). I put 295/60r20 on stock wheels. They had a very slight rub on front inner wheel liner at full lock, but it was fixed easily by a zip tie. I originally put 275/60 on there cuz the tire shop didn't thing the 295/60 would fit. They were wrong! The 295/60 looks 100% better. I have Toyo Open Country AT 2. The 295/60 is the Xtreme version so it is noisier/heavier than the 275/60 due to the wider Xtreme tread pattern...but it looks way better! I also added a 1/4" RCountry spacer to the wheels to get a little more width for astetics.
I was looking into those tires but could not find them in my area to compare to the duratrac. They had the 275/65 r20 which is a not extreme size ??? the dealer here didn't even know the difference between the extreme version.
Overall happy with what I got but yours look nice too . :thumbs:
Heres my truck.. got it last thursday. '15 gmc sierra slt, 4x4 z71, summit white w/ jet blk leather interior, loaded, 22" sye wheels, etc. got a linex ultimate bed liner and I did the rc 2" front lift.
Not great pic.. from my cell
Really good looking truck. Good luck with it!
Edited by JimmyVal
Well here's mine, finally finished everything up. Level kit, tint, new tires and debadged. Weird thing is, I feel every bump in the road with these tires, like they are a harder tire and everything travels to the floor boards...oh well.
Might have got a 10ply which is a stiffer tire
I didn't think of that, I mounted and balanced them myself, all of them took less then 3 oz, but one tire took 6.25, that tire has me worried.
Thank you for the link, I'm not planning on doing any offroading but in not sure if I trust that type of spacer.
Edited by bfel816
What size tire and what psi are you running?
285-70 17, mas is 44 PSI, I'm running 40 PSI...
10403476_417902061702696_728512716255366
Just picked up my brand new 2015 GMC Sierra Z71 Double Cab. Ordered a Rough Country 2.5" leveling kit today. Still not sure which tires I want to run. I am looking to run the biggest tires possible width wise without hitting the suspension parts underneath. Eyeing 275/60/20 's right now. Gonna keep the stock rims and not afraid to get some small wheel spacers if need be. Any info on the rims that come stock on this truck would be appreciated. I am thinking they are +26 offset but not entirely sure.
Thanks all.
Jordan
I would be willing to bet that it's due to two things. Your psi and the level kit. I had a spacer level on my truck before going with rancho quickliftsthis weekend and it rode really rough. Lowering my psi to 33 helped, but in the end getting quicklifts was way better.
Edited by projectsummit
Just picked up a set of Bilstein adjustable shocks front and the rear to go with them. Autozone spring compressors work fine for the install or should I order something better?
If it's any help, im pretty sure my neighbor used some Autozone or Pepboys spring compressors when he installed a set of Bilsteins on his 06 2500
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
