Here's mine so far. RC 2.5" level/Lift 20" XD mavericks w/ 275/60/20 KO2's removed assist steps HIDS on front w/ LED fogs LED reverse/license plate lights tinted windows. Need to figure out what I'm going to do as far as a sub and shell probably be done/DSC_0283_zpso6iax4jt.jpg]\
i just recently bought a new 2015 gmc sierra AT package having a 2.5 RC level installed this week and just ordered 285/60/20 duratracs....am i gonna run into any rubbing issues...i see most people here are running a 295 or 305 with small to no rubbing issues. any input would be appreciated thanks.
usually those running 295 or 305 are running a 18" or a shorter tire. Im running 275 no rubbing it would be getting close w/ 295 pending on tire. You may have non or just a tiny bit
I own FastHeadlights LLC and we do work on headlights all the time. I just took the orange out and replaced with some switchback turn signals :)
Do you have a link or a video on how to modify the lights?
Edited by rubens megatron
I just did a lot of work on my lights. Used the same method to open them that Phil does. Check it out, may help you out
http://www.gm-trucks.com/forums/index.php?/topic/171698-Mike1220%27s-SLT-Sierra-halos%2C-color-change-DRLs%2C-and-FXR-retrofit-w
oh, I was kind of hoping it was available as a preassembled after market item like a plug n play. I wouldn't want to risk messing them up, so id rather pay a little extra for a prefabbed pair, but thanks for the link and the info
4" leveling kit with 2" blocks in rear
Could you post a couple more pics? That stance looks perfect. What's you wheel and tire combo?
Just did a custom leveling kit. RC 2" Spacer in the front and bilstein 5100 struts at .6 lift. And in the rear I used the 2" RC block and bilstein 5100 shocks.
The truck rides 100% better then stock Rancho Shocks. Smooth and controlled over bumps and that stupid hope the rear end used to do is now gone.
Front end is 39.75 and rear is 40.75.
Super happy with stance and ride. Would recommend this setup.
Got any pics? This is what I was going to do but held of because I wasn't sure how the ride would be.
Yes more pics & i agree perfect stance but where did you get the level kit from? Edited by cameronfaber
Very interested in this setup as well. So I second the pics request. Lol
Has anyone else noticed a mark where their spindles and lower control arm are coming in contact after leveling? I have the mark on both sides on the front side of the lower control arm. xLwiYs7.jpg
Edited by projectsummit
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
