Yes, if you are going to put a rear block on, put it on before the alignment. Part of your alignment is checking that your rear wheels are tracking directly behind your front tires. If the rear axle U-bolts are tightened with the new blocks without checking "square", you will get rear tire wear. Measurement from center wheel front and back should be the same on both sides of the truck.
Thanks. Makes sense now.
Oaks I have previously installed sumosprings on the back of my truck. Currently it is just so they touch the rear axles. When I install a 1 inch taller spacer in the rear they will obviously be spaced out another ~inch. Has anybody ever run into this situation before? My thought is to make a spacer and get a new bolt to make up for the inch spacer for my sumosprings. But if there is already something out there I would like to know.
Kerrs, I'm the same way. I probably saved over 10k in labor costs over 11 years doing everything to my srt4 myself.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Only thing I'm worried about is having issues with warranty crap at beck n masten when I take it in for service.
I bought my truck from them. I leveled it the day after I got it and had it aligned. I had it at the dealership for the free oil changes and some service issues. They brought up my level at one point but it was never an issue. I had a steering issue, getting a popping while turning and they replaced my ball joints and steering gear all covered under warranty. Very good service dept to deal with. Never had a bad experience with them.
Yeah Kerrs, they do have a good service department for sure. Thanks for the input. Looks like I'll be doing that this weekend.
Hey
just looking for a bit of help advice. I put in the rancho quick lifts and haven't been to impressed. the ride is very stiff. when going over speed bumps it just rocks you. the front end jumps like crazy. is there any way to help smooth this out? ive tried all settings of the shocks and they are just stiff. my wife isn't a fan. Im thinking about doing something different if they are going to be this stiff. Just not a fun ride.
aswell the dealer said they cannot properly align the front end so I have some wear on tires and my steering wheel has a slight told to the right. and doesn't return to center like it does when it is a left turn,
is the dealer just inexperienced? I know lots of people run these quick lifts so it must be doable to align properly. should I take to a alignment shop or are they correct that with the 2 inch lift you cant quite align it
Thank in advance
Hey
Thank in advance
I know someone that has these shocks and has them aligned just fine. You should be able to get them lined up. Not sure why they are so stiff though. Do you have ranchos on the back as well?
You could try the bilsteins... lots of people seem to like those on here.
Edited by tyrich88
Check out etrailer.com. I'm running Timbren SES's on my truck, which are similar to SumoSprings, except they sit just above the axle when empty, and only make contact when loaded. Same concept as the SumoSprings though. I have a 2" block in place of my factory 1.25" block in the rear, which would have created too much distance. When I bought my Timbrens, I also purchased a 1" spacer from etrailer.com that mounts above them. A trip to the local hardware store for some longer bolts was all it took to make everything work just fine.
Hey
Thank in advance
As stated, my folks are running the Rancho quick lifts with good results. Do you have any other suspension modifications besides the quick lifts?
2" Rough Country - 275/65r20 BFG AT K02
23570646493_d39a6b2837_z.jpgUntitled by Dustin Wince, on Flickr
23829643149_cd06c9cd7f_z.jpgUntitled by Dustin Wince, on Flickr
Where do you live and can you take a whole picture of your home? It looks really cool from the way the garages look.
hey guys, i just picked up a 2" RC level. How much are shops charging to install them and then align the truck? just curious, i figured it should take an hour and a half -2 hours of labor.
I paid $250 for installation. That included labor, tax and allingment.
Talked to my shop and I am going to be getting my Bilstein 5100's installed next Friday. Unfortunately they didn't have the KO2 tires in stock and they are back ordered so I will be shopping around for them for awhile.
New guy here. Picked up my 2015 Silverado in November after trading in my 2012 Sierra and am enjoying the upgrade. Just got it back from the local shop and had a 2.25" readylift level installed on front and 2" block installed in the back. Wheels are 20" Dropstar 645b +18 mounted on 33x12.5x20 Toyo M/Ts. Surprised there was zero rub issues with this setup, as I had to trim plastic with this same setup on my Sierra. Pardon my absolutely filthy truck, we got hit with some snow yesterday and the DOT went a little nuts with the salt. I'll post some more once I get her cleaned all cleaned up.
Measurements before:
Front: 37"
Rear: 39"
After:
Front: 39.50"
Rear: 40"
Before:
After:
Edited by buckeye6
Ok, dealer may be inexperienced. I will try an alignment shop. I just didn't want to be taking it to 2-3 paying for it and in the end it cant be "perfectly" alighned.
No mods just the quick lifts. I do have the rancho rears and a block, but if you drive a speed bump on the front end that's big wow do you ever move on the front. you bounce. so to me it seems like the springs are to stiff. Ive tried all settings and they react the same.
just a bit disappointing, I don't quite remember these days what the stock ride was like but vaguely remember it being very smooth and comfortable. I avoid speed bumps because you bounce so bad!
I finally got my Bilstein 5100's put on, front only. I have a 2014 double cab Z71. I got exactly a 2" increase in the front. In my opinion it seems to be a great improvement over the stock ranchos. I still have about an inch and a half of rake which I am fine with.
After Installation
Front driver's side = 38
Front passenger side = 38 1/4
Rear driver side = 38 1/2
Rear Passenger side = 38 1/2
Stock, 12 months before installation
Front driver's side = 36
Front passenger side = 36 1/4
Rear driver side = 38 3/4
Rear Passenger side = 38 3/4
Edited by Guru
    juggernautusa
    juggernautusa
  • Who's Online   1 Member, 0 Anonymous, 532 Guests (See full list)
