I have a 2016 and I'm not sure whether I'd need the aluminum or steel version of the RC 2.5" kit. Is this just a preference or does it matter on what your truck is actually using for the stock control arms? Sorry if this is a noobie question, but I just got the truck and am still learning.
It's important. You use the kit that matches which controls arms your truck is equipped with, steel or aluminum.
That's what I thought, but wasn't entirely sure, thanks. Unless someone can tell me, I guess I'll grab a magnet and climb under the truck.
I've had a 14, 15, and now a 16. The black arms have been steel and silver were aluminum from my experience.
anyone know what the 2015 1500 high country has for control arms, id go look but im deployed ;( and id like to order the kit prior to being home
Awesome, thanks!
Yep, the magnet test is pretty full-proof, haha.
Not the best, but at least it's not in the driveway. I love the final product.
Sent from my Nexus 5 using Tapatalk
anyone here running a Toyo 33x12.5/20r open country m/t with just a 2.25 level? I ordered my rims recently and trying to size the biggest tire i can squeeze on. Rims have a +20 offset so pretty close to stock.
Haven't put on tires on the 15 yet but have seen trucks with a 2 inch level running 33's on stock wheels. I think you should be fine with that offset with a 9 inch wide wheel on your truck.
I thought so to as the level kit states you can run a 33" but says a 11.5 max, I want to avoid rubbing at all cost.
I just put on a 2 inch RC level on my 15 crew cab happy with it so far about 500 miles on it. For those guys who have 2014 & have had them on for a while is there any negative impact that come directly from having it leveled? Just curious if I should be worried?
Sent from my SM-N920R4 using Tapatalk
I think Laura Buick GMC puts +1 offset 20x9 rims on the trucks that they level with the 2.25in level and run 33x12.5 at tires. I have also seen ppl on here running 295/55/20 (33x12.2) mts on stock rims with 2 or 2.5 levels with no rubbing. With +20 you're gunna be cutting it close.
For those with the moto fab 2" level, did it give exactly 2" of lift. Also, where can the top 1/2" spacers be purchased?
I put on the 2" Level with the 1/2" top spacer this last weekend. It worked out to be a little greater than 2.5" of lift, nearly 3" to the bottom of the fender in the front. I have a '16 CC Sierra with factory wheels, and it currently sits close to level, but back is nearly 3/8"-1/2" higher.
One thing to note is that the front end on mine looks a little bit higher in the front because of the profile of the hood compared to the box, so it depends on your goal for the truck. If you're going for looks you may want to go with a 2" leveling kit, but if you're going for tires and want to have more clearance you may want to go with the 2.5" lift.
I didn't add anything to the rear yet, I wanted to try the front first and see how that changed things.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
