Do you guys know if a 33x12.50 tire can be run on the Silverado with just a leveling kit?
2016 Silverado LTZ Z71.
OEM GM 20x9 +24 offset wheels. Clear coated PVD Black Chrome.
Nitto Terra Grappler G2 285/55-20.
Bilstein 5100 Ride Height Adjustable shocks on highest setting. No rubbing. No trimming.
2014 Lt 3.5in Rough Country, 305-55-20 Destinations, 20x9 Moto Metal 970,
What offset did you go with on the 970s, +18 or +00
Well this sucks, I called the dealer I just purchased my 2016 Silverado from to ask them what they charge to install a leveling kit. They quoted $160 in parts, $230 in labor and $84.95 for a front end alignment. When I told the girl I will just bring it in for an alignment after I install the kit myself, she dropped the "that will void your warranty" bomb on me. Really?
I bought my Silverado this past weekend and they told me the same thing....
Why do you expect them to say? Yeah alter the truck and we'll still take care of it!
Sent from my SAMSUNG-SM-G930A using Tapatalk
I've had plenty of cars in the past that I was able to mod and not void warranties. I also never said I was mad about it and was only responding to the other post above mine. I also understand Chevy's stance on warranty issues on suspension and engine pieces, and that is fine. However if a person were to have a leveling kit or anything else done, and it is by a competent shop, then you would think that they would be a bit more friendly towards it. Enjoy your day.
Basically this rubbed me the wrong way. My last truck was a Ford with a 6.0 Powerstroke. God knows all the problems with that engine. My service writer at Ford had no problem with the fact I was running a programmer. This kinda pissed my off as far as my new chevy dealer is concerned. And yes, basically because I told them I would install myself and not pay them their high fees. Just tell me one thing. Has Chevrolet denied everyone warranty who went off and installed these huge lift kits and put on huge tires???
Chill out bro you take things the wrong way.
THEY ARE +00
Any pics down the side?? The other pics make it look like they are sucked in a little when they should be flush or a little outside the finder. Thanks
I leveled the front with a 3" kit from CCm Offroad (The kit I used fit 2007-2014), I also have air bags in the back I tow a trailer and didn't want the back to sag. the tires are cooper neon ltz 305/55r20
I also painted the center caps of the rims to match the rims. De badges and tinted the windows.
Looks good. When you debadged the truck did you remove the chrome door strips? Any difficulty?
I can prolly put some on today, they are not flush, there is some outside the fender
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
