Called up the dealer and the first guy i talked to for a ready lift 2.25 level and alignment wanted 1200 dollars..... absolutely absurd. So then I had a friend who owns a body shop call the same dealer (parts guy instead of service guy) and they told him 475. I know everyone knows how dealers mark up everything but by upwards of 700 dollars?! Thats just wrong.
I was quoted $575 from my dealership for the same kit installed and aligned. There is a huge discrepancy in prices for levelling kits and installation! Just for a bottom of strut 3/4 inch thick aluminum spacer identical in shape composition and function (part only-different brand) range in price from $35 - $175! Installation quotes are equally diverse. The range in knowledge on this modification by professional installers is also quite incredible.
That's what I thought, but wasn't entirely sure, thanks. Unless someone can tell me, I guess I'll grab a magnet and climb under the truck.
Black is stamped steel - silver is aluminum..
So it looks like all the kits people have commented on thus far has the spacer above the strut mount. i tried to online chat with rough country but after i asked the question the rep ended the chat. so has anyone tried any brand spacer with the new stamped lower control arms?
One reason I haven't done it yet is because I don't want to void the warranty.. and I've heard on here that any suspension mods will void warranty for suspension.
It is on them BY FEDERAL LAW to PROVE the modification caused the damage, which is difficult for them to do so it shouldn't be an issue, especially if you have a good relationship with your dealer.
My dealership has a 2016 Silverado in their parts showroom with a standard 2" aluminum lower spacer with the stamped lower control arm. I forget the brand but it is discrete and looks great!
I have a 2.5" RC with the RC 2" rear blocked stacked on the stock block. The truck has a 1"- 1.25" rake and I like the stance since I tow a boat. But man this sucker rides pretty rough. I was going to remove the RC rear block and see if that would help but that would eave me too level for my taste. Do y'all think by me removing the front top spacer Ian's rear block it would help,that much?
Thanks
Edited by mmwest
Thanks
what kind of wheel tire combo are you running
Thanks
Never stack blocks...removed the original block and put the RC in alone. The trucks come with 2-2.5" rake from the factory, so raising the front 2.5" and the rear 1" with the replacement block will retain about 1" of rake. That's still not enough if you tow or haul anything, so look into Firestone RideRite Air Bags. It will change your life.
If the ride is too harsh for you, going from a 2.5" level to a 2" level is not going to change much. I found my truck road close to stock after the level, so I would put the blame on those 20" rims. Less rubber + more rim = harsher ride. It will only get worse if you go up to a stiffer LT tire.
If ride quality and lift is that important to you, than a level may not be your thing. You may need to go to quality 4" suspension lift or a small body lift.
Thanks
You have got to be kidding me, stacked blocks? Very unsafe, I would fix that ASAP, and never tell anyone you did that haha.
TGC 2.5" kit
33x12.50r22 Toyo MT
Fuel Hostage 22x11 -24
Front still sits a bit lower than then rear, only rub in reverse at full lock
5CF68855-4C34-41B7-9B5A-AF93F081DF0D_zps
I know,I know!. This was a dealer installed third time screw up (long,long story) and this time I'm moving on to a local shop. Going to definitely remove the stock block and go from there.
Ahh I see. Definitely never get any work done st that dealership
It is not difficult for a dealer to show a modification caused an issue with something. What is difficult is a person showing it didn't cause an issue when the dealer/and/or/GM showed it did. Happens more often than you think, especially when those that actually engineered and designed the vehicle are called to look at it and say otherwise; don't you think they would have the best idea?
If spacers are put in and a ball joint or CV axle fails, pretty easy to call out. Now trying to explain how a spacer caused a radio failing yeah, not going to happen. But the guy mentioned a spacer causing suspension warranty problems which is no where near out of the realm, so lets not go spreading false information...
CMP, as BCM noted it has to be directly caused by the mod, so while it can cause suspension warranty issue that part has to be the cause. It won't immediately wipe out your suspension warranty, it can just do parts of it if a failure happens and that was the cause. Wait until the warranty is up if you are worried. Either way most suspension fixes aren't ridiculously expensive like trying to replace an engine after a tune was on it and caused the failure.
Good luck, I personally am waiting until the stock tires are gone and going up. By then the warranty should be done (though I will still have the powertain) and it will be on my regardless.
Tyler
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
