rough country add a leaf which added a inch and a half the I put 3 inch supreme suspension leveling kit
2016 Silverado
2 1/4" Front Level Only
OEM GMC All Terrain Rims, Plasti dipped black with Glossifier
Midnight Edition Center Caps
275/60/20 BF KO2's
Zero Rub, Perfect Fit
2016 Silverado
275/60/20 BF KO2's
That looks really good.
Which kit did you go with? And how does it ride now compared with before? Do you still have the stock shocks?
I'm not sure what kit, the dealer put it in because they cover it under warranty even though I am extremely hands on person, I had that worked into the deal when I bought the truck. Its the stock rancho shocks. Been running the tires at 39psi cold. I personally think it rides better then the stock Goodyear's, handling has improved along with comfort. You can hear a little noise almost barely noticeable
2016 Silverado
275/60/20 BF KO2's
Exactly what I'm looking for. Thanks boss!!
Sent from my iPhone
Ok done tons of research. Want to go full lift later down the road. Still on stock sle 20s on my 2015 gmc 1500 and factory Goodyears at 30k are showing some good wear. Have the rc2.5" w/2" rear block. Looking at nitto trails on these wheels size 35x11.50r20 see a few guys doing 35x12.50r20 with levels also looking at 295/60r20 cooper stt pro and toyo at2 also 295/65r20 in the toyo at2
Any experience with these sizes. Have the front valence removed just don't want to rub metal. I do use truck Offroad lots.
I have been running 35x12.50x20 on stock rims with an RC 2.5" level front only for about 12,000 miles now. I did some minor plastic trimming but still rub at full lock. I have had it in mud, on medium trails, and on the beach for two years. I have Firestone Destination MT's and they run pretty true to size. They look great and are definitely worth it if you go offroad even semi regularly. You gotta love to scrub though.
Edited by Jfcampbell485
attachicon.gif20150713_170935 - Copy.jpgattachicon.gif20150630_200600 (2).jpg
I'm guessing your rubbing the sway bar pretty bad then?
    Clark_Elite
    Clark_Elite
  • Who's Online   5 Members, 0 Anonymous, 384 Guests (See full list)
    • Glad I found this post before posting a question. My ‘09 has been throwing those codes and P0442. I replaced the gas cap as it was trashed to begin with and the purge solenoid valve under the hood but still get the code every now and then. Dealership said I need to replace the vent lines as the previous owner use cheap fuel line that feels more like a balloon. They also said the charcoal canister and the “canister vent solenoid/service kit” so it relocates the filter up by the top of the transmission. Vent solenoid is cracked as the previous owner just let it hang loose. Too lazy to put it back on its bracket. If I put it on there the hose kinks and I thinks causes a whistle when I fill up.  Only issue is the parts guys can’t tell me which one I need as it shows two styles. One has a jointed section. Which should I use?  Thanks.  I apologize for hijacking the thread
    • UPDATE 3: Supposedly you need any cluster OTHER THAN a WT model cluster to have full steering wheel functionality. Went back to the part truck and removed the all terrain cluster, trim, and snipped as many wiring harnesses as possible to pull out the factory terminal leads if needed 😂 that poor donor truck…    As of right now I’m relying on Darth_Vader’s thread and YouTube videos. will update.
    • Was commenting on the engine labs article on lifter failure.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
