Has anyone done a 2" in the front and 2" blocks in the back? I would like to keep some rake to it and thinking about getting the kit from motofab. Just wondering if anyone had pics of it done and quality of the kit. Thanks
I did 2.5 in the front and a 1 inch bigger block in the rear (2.25" replacing the 1.25"). Maintained about 1" of rake, meaning the 2.5" with nothing in the rear probably would have made mine dead level
Maybe I am just a bit old school but IMO without a 6" lift and 37" tires the 20" wheels look like they should be on some low-rider and not a 4x4 truck. I guess I'm just getting old because it seems like everyone and their brother is running 20's. Hope everything works out with your new wheels, tires, and leveling kit. I know the tires I have are big for 285/70 or at least that is what I have read in comparison to other brands of A/T tires in that size.
I agree completely. Especially MT's on 20's. even with 35-37's, I'd still run 17's or smaller lol. I had 35/12.5r16's on my lifted '03 Silverado. Thanks for the good luck on the wheels and tires. I'll be sure to post pics and info on fittment.
Haha to each his own. I could agree with you that aggressive tires below like a 33 with 20's looks a little funny. But IMO anything 33+ looks great.
Not a fan of these kids stretching 24x14's on 33x12.50's though lol
2.25" ReadyLift Leveling Kit with 285/75r18 Toyo AT2 Xtremes. 70941cb98324dc9db82b6647449330a6.jpg86ea49e2c820412929c45f1ef6937ef4.jpgb79e4f1114870ac5bfb0c2864039c235.jpg
Yeah true. Not a fan of all that either. I've decided on the motofab 2.5" front kit but I'm going back and forth between the 1" and 2" blocks to go in the rear. Do you have any pics of your setup?
This is all I have at the moment.
I've heard nothing but bad things about the previous generation Falkens, so I hope these are improved. They do look better than I thought they would. It might have been asked before, but do you have any lock-to-lock pictures of clearances around the UCA and the swaybar? I think you mentioned you had to zip tie the liner.
Edited by bcbz71
Looks really good. I have earmarked that size as a possibility since the 295/65 comes in so few options.
So through all the pages of this thread I know some guys are running the 2.5" front with a 3" block. What is your rake like? Pictures would be great!
Thanks man. Have you looked into a 295/70? Quite a few options in that size as well, and the size looks great. It's a 34 inch tire. The 285/75s are a 34.8 x 11.50.
2.5" front/ 3" rear
295/70r18 on stockers rub UCA and Swaybar with a 2.5 level. They work with a 1/4" spacer but I'm against running spacers if I can avoid it. I have to be careful about overstuffing because I put my truck in some tight spots when hunting, and need my full lock to lock for towing (specifically backing up).
Oh ok gotcha. Im the same with my truck about the tight spots while hunting. I didn't realize the 295/70s would rub UCAs and Swaybars. The tire shops around here put a lot of 295/70s on stocks on these trucks. The only thing I wish I would've done was went with a mud tire when I bought mine. Good luck.
Nope, zero zip ties or trimming, and no rubbing at all. even at full lock in reverse. I will take clearance pictures tomorrow and post them. Hopefully Ill get around to washing it too lol
PS: Keep in mind, this is with a 2" level. I think I found the absolute limit of a 2" level setup.
Edited by rawalters117
Woychc- where did you get the 3" blocks? I found a few on fleabay but I don't know if those are the correct ones. I also know Ready lift has a kit but it's 120 bucks.
Mine were from rough country
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
