Finally did a level lift on my 2014. These reg cab trucks are famous for the nose dive front end they have. 2" level on front and also added a set of 285-55-20 Toyo AT tires. I just can't believe it is the same truck when you stand beside it. The stance now makes it look like a lot more truck!
Edited by Likarok
If you want it to look even higher take off the air dam. now that it is level that air dam is causing more drag/resistants, but if you like the look leave it on. All looks good.
Looks good. Three inches of rake on a regular cab looks way worse than on a longer wheelbase.
I'm not trying to be an ass. But how do you know that the air dam is now causing drag/resistance? Have you seen evidence, or is this an assumption?
You're not being a ass, if you don't ask you won't learn.
That air dam like all car air dams are made to push air under your vehicle or push it off to the side to make less resistance on your vehicle.
After you lifted the front end of your truck the air is now pushing against the dam and not flowing under it smoothly. Basically working as a spoiler now.
Pretend you are in the water, and you need to push a long piece of wood across if the wood is touching the water, at a 110 degree angle ( like your air dam was) it's not so hard, the force would be at the top and water would go off the sides. Now move that to a 90 degree angle (where it is now) the force will be much greater and not as controlled.
I understand the logic but that's assuming the only factor at play is the angle/height of the dam. This is ignoring all of the non-aerodynamic pieces hanging below the vehicle. Take your example and place things that create drag behind that piece of wood and even if the wood is moved up or at a different angle it will help in reducing the drag created by that in which is behind it. I appreciate your time and response. And hope this can be a constructive conversation.
I am a mechanical engineer in the aerospace industry so I've dealt quite a bit with drag and the likes. I've just always assumed that the dam on a truck would be beneficial regardless of height and angle (unless you are lifted high). I am leveled with the dam on and am curious now if I would see and change if I removed it. I believe that I would. My thoughts on this, are that the dam will still push air to the sides and lower towards the ground away from the drag behind it. As well as routing the air around the tires towards the outside, which believe it or not, are huge sources of drag.
Yes, but you are forgetting that the wind will be pushing the air dam back (it has some give on the sides from being so long)
also the rubber skid plate, it's angled to avoid wind from hitting your axle and other low hanging objects. I currently have mine off (going to be painting it) so don't think I'm strange for having it off, I didn't go under my truck to make a point lol.
9dfe163700a34c2443e5df6208a4c188.jpge4d2e1a27801b996fe9b257578f04aca.jpge49c5e20bfef591233a6f67c59ce146d.jpg
If anyone here can drive so consistently that they can actually tell how much the air dam affects their mpg, my hat is off to you. Until then, all we can do is assume it works to reduce drag on stock vehicles because GM has it on there and it may or may not on leveled/lifted vehicles. But if you're already leveled/lifted, do you really give a flying hoot about a 1/4 of an mpg over the looks? So do whatever you think looks better.
I mean, I get it, it's fun to debate how the air dam affects it. But without a carefully controlled environment you're not going to get an answer. So you're pretty much just bloviating.
I agree that a 1/4 mpg isn't much. It's been stated that the difference is a 1/2 mpg, but that isn't really the point of the conversation. It's definitely more of friendly discussion. However, saying we just have to assume it's there because of mileage is not necessarily true. In an industry, world for that matter, where designs are driven by the mighty dollar an extra piece of plastic wouldn't be added for no reason. There is a gm published video showing the results of the dam and it's quite amazing. This is definitely included on the vehicle to help meet the demands of the federal gov for mileage.
Like you, I think the 285s look "OK" on these trucks, but not great. The more I look at this setup, the more I like it.
Can I get some more pictures? I'm especially interested in some pictures of someone holding the steering at full lock, and seeing the clearance around the tire (front, rear, UCA and Swaybar).
Finally got around to snapping these pics. Its tough to really get a good angle at it, but there is zero rub. I have about a 1/2" of clearance. It seems like now that the GM wheel wells are a tad more boxy than earlier models, we also have a bit more room to hit bumps while turning/in reverse also. My driveway is pretty steep, and when backing out at an angle, I still dont rub at full lock. That being said, Im pretty confident in saying I found the absolute limit as far as tire size goes for just a 2" level and stock wheels.
8822D3DE-4665-4CCF-8A9F-2E1A80BEE526_zps
DB9D6C5F-0584-47FD-9EE0-50C407DBD4C9_zps
Thanks for pics. That's certainly a tight fit. Did you see any rubbing on the UCA or Swaybar? Those tires don't have wildly aggressive sidewalls, so any rubbing there might not be that noticeable in lock-to-lock turning.
Can you take true mounted measurements of the height (vertical and horizontal) as well as the tread width and section width (eye balled)? I'd like to compare your measurements to the Nittos I'm running now.
Hello, new to this forum but have been a lurker for a while.
Thought I'd post my setup for reference:
2017 Silverado 1500 LT Z71
Just put a motofab 2" level kit and Falken Wlidpeak A/T3 in 275/70/18 on stock 18" rims.
I do have rubbing on upper control arms at full lock. Tires at 40psi.
Thanks!
For those who've done their own leveling kit:
I've done several on my previous vehicles, and a fair amount of front end work in college, but.... I attempted to pop the upper ball joint this week, on my new Silverado, and it wouldn't budge. I used a pair of 3# hammers (one one the left side of the knuckle, the other swung from the right, and vis-versa.) Nothing! Puppy is holding fast!
A friend suggested that the knub on the back side of the knuckle was the appropriate target point... what's your experience?
Yeah, that was a complete b**ch. I alternated smacking front back and that nub on the frame-side with an engineering hammer until my arms were on fire. I ended up running the nut up super tight a few times then hammering. Seemed to work a little better.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
