What wheel size do you have? I have the same size 2.25" level in front and 3" blocks out back on my 17. I'm running 295/55R20 Nitto Ridge Grapplers on Sierra reps that have the factory offset. Minor rubbing on the plastics at full lock. I could probably zip tie them back and clear them but I'm lazy. f68d498d4c0768ca9ad6430dd085df34.jpg
Sent from my SAMSUNG-SM-G920A using Tapatalk
Currently running the factory 275/55R20 so 20". Nice Truck.
Thanks
Hmmm .. they fit with just a 2" lift in the front ?? They are pretty slick !! I just googled and found this. 7b7718c59b9ddaf24608cbde8fa9f13a.jpg
That's a 4.5 inch Zone
So how do you reduce the dice of a picture to be able to post on this site.
#cantfigureitout
Use the tapatalk app. for the forum. It will resize for you.
Thank you sir
#cantfigureitout
Thank you sir
Sent from my iPad using Tapatalkpost-175204-150436992568_thumb.pngf4477778dd0560ddc72575ac5e83a878.jpg
Edited by cowboysfanmd
Glad to have it back and it's beautiful!!!
2016 Silverado
2.5" Rough Country Lift
Moto Metal MO970 20x9 +0 Offset
Toyo Open Country RT 295 55/20
2016 Silverado
Looks awesome, trying to decide on the tires, hope to make a decision before weekend ends. The YOYOs look great. I think its now between the TOYOs and Terra Grapplers.
I did the MotoFab 2" level kit up front on my '17 Sierra 1500, and I have had it in for just over a week. I'm getting some slight wheel rub on the left when at left turn lock. After reading through I'm thinking this shouldn't be. The guys at my local alignment shop had a helluva time getting it aligned. Took two trips before the camber and toe was right, and upon getting camber/toe dialed in my cross caster is out one degree to the right side. -0.4° left and +1.4° right. Any advice to be had? This is an Elevation Edition sitting on the factory 20"s with the factory 275 55 20 Conti's
Edit: I guess -0.4 and 1.4 is really 1.8 huh...
Edited by nmyron
    todd wollemann
    todd wollemann
  • Who's Online   3 Members, 0 Anonymous, 532 Guests (See full list)
