What wheel size do you have? I have the same size 2.25" level in front and 3" blocks out back on my 17. I'm running 295/55R20 Nitto Ridge Grapplers on Sierra reps that have the factory offset. Minor rubbing on the plastics at full lock. I could probably zip tie them back and clear them but I'm lazy. f68d498d4c0768ca9ad6430dd085df34.jpg
Sent from my SAMSUNG-SM-G920A using Tapatalk
Currently running the factory 275/55R20 so 20". Nice Truck.
Thanks
Hmmm .. they fit with just a 2" lift in the front ?? They are pretty slick !! I just googled and found this. 7b7718c59b9ddaf24608cbde8fa9f13a.jpg
That's a 4.5 inch Zone
So how do you reduce the dice of a picture to be able to post on this site.
#cantfigureitout
Use the tapatalk app. for the forum. It will resize for you.
Thank you sir
#cantfigureitout
Thank you sir
Sent from my iPad using Tapatalkpost-175204-150436992568_thumb.pngf4477778dd0560ddc72575ac5e83a878.jpg
Edited by cowboysfanmd
Glad to have it back and it's beautiful!!!
2016 Silverado
2.5" Rough Country Lift
Moto Metal MO970 20x9 +0 Offset
Toyo Open Country RT 295 55/20
  • Like 3
2016 Silverado
Looks awesome, trying to decide on the tires, hope to make a decision before weekend ends. The YOYOs look great. I think its now between the TOYOs and Terra Grapplers.
I did the MotoFab 2" level kit up front on my '17 Sierra 1500, and I have had it in for just over a week. I'm getting some slight wheel rub on the left when at left turn lock. After reading through I'm thinking this shouldn't be. The guys at my local alignment shop had a helluva time getting it aligned. Took two trips before the camber and toe was right, and upon getting camber/toe dialed in my cross caster is out one degree to the right side. -0.4° left and +1.4° right. Any advice to be had? This is an Elevation Edition sitting on the factory 20"s with the factory 275 55 20 Conti's
Edit: I guess -0.4 and 1.4 is really 1.8 huh...
Edited by nmyron
    Greg3160
    Greg3160
  • Who's Online   0 Members, 0 Anonymous, 416 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
