Running the 2.25" Readylift leveling kit up front, has the upper and lower spacer. Also added the 1" taller block out back. Only about 5k miles on the setup so far but no issues and rides fairly well in my opinion. Tires are 305/55/20 on 20x10, -24 wheels. I did have to trim some plastic and zip tie the fender liner back, still rubs in reverse while turning but nothing serious.
8c03cee41c4bffcddd69ef4196f317cb.jpg4fb3cd23452908a493f2c8462ae10522.jpgbee623a58c57fc8bf0244327acaf6bbd.jpgcf39a752a9404ed972218ea0cca0d439.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
On 12/27/2017 at 4:07 PM, steve76t said:
Leveled!  Rough Country 2" Magride level kit with 285/55R20 BFG KO2 tires.
What is the rake on this if you do t mind me asking? 1 1/2”?
12 hours ago, JSB81 said:
I have a 2018 Seirra Denali 1500 with a 6.2 and added a RC 2.5” leveling kit. With leveling kit in and when 4 wheel drive engaged it have a pretty good vibration when engine is under a load. Anyone else have this? Take leveling kit out and it goes away.
Sounds like your u joints are out of phase.  Is ur rear block installed?  Some guys leave out the rear block.  U could experiment like that or I'd get ahold of rough country and straigten it out.
Also make sure it's compatible with magneride
Edited by Tyy1907
We actually took rear block out and put 2” in the front. Didn’t make a difference. Also put spacers and dropped deferential. Nothing changed.
That's odd. I had no issue. Did you have the dealer "re-zero" the magnaride? basically after you do the level the magnaride thinks its in a giant perpetual bump and will ride like a dump truck until you do this.
Yes they did. I’m sure it’s one of those crappy luck deals. Put the 2” kit in a 5.3 Denali and all the problems went away ??‍♂️
Yup, almost 1 1/2" exactly.  It's 1 3/8" on the drivers side and 1 1/2" on the passenger.
Looks great!  With regards to the ReadyLift...do you have the option to only put in the top round spacer and leave the bottom U spacer out or do you have to install both?  Also do you happen to know how much of a lift you would get by just putting in the top or bottom spacer?
Thank you. You could leave one or the other out. I believe the upper spacer raises it 1.5" and the lower gets you the other 3/4" but I'm not for sure on that.
On 2/17/2018 at 3:24 PM, 6.2_GMC_DEN said:
Installed 5100 Bilsteins with 2" Level and 305/55R20 Nitto Terra Grappler G2. The ride is better than Stock which was really good, this thing is super smooth and quiet quiet quiet! I also added 8mm spacers to ensure no rub and I did not have to trim anything. One thing I think folks need to consider is doing a performance balance on their tires and I am absolutely not talking about Roadforce. We took Static down to under .05oz and Dynamic to under .10oz a tire and this thing rides like butter. I am super happy with this set-up!
Can you elaborate on the "performance balance?"  I have the same tires (XL rated).  Could only get the road force balance down to 16 & 19 lbs. on two of the tires and it is evident at highway speeds.
Installed a 3" Motofab level on my 2016 Silverado Z71 last weekend. Rear is stock. Wheels are 20x12 -44 offset and tires are 33x12.5. Took some plastic and metal trimming, no rub at full turn. Before and after pics below. Smoking my turn signals and corner markers this weekend.. will probably vinyl wrap the chrome bumper mustache too.
That is a great looking truck! How are you liking the Atturo's so far?
Loving them so far. Only have about 400 miles on them. They growl a bit at low speeds and hum over 50+, but I actually like hearing them. Nothing overwhelming. Very smooth for a mud tire. My little brother has them on his 2009 and they're wearing very nice.
Good question.
First question would be do you feel steering wheel shimmy (side to side vibration or Couple vibration) or do you feel in your seat or dash area a hopping sensation (up and down vibration or Static vibration)?
My performance balance method is done by mounting the wheel correctly with low taper collet on back side of wheel and using a pin plate to secure wheel by the lugs. I then put my direct drive COATS Balancer in "fine mode" (opens blind under .25oz) and remove all residual unbalance to under .10oz. In most cases I get it to .03 to .01oz where a Hunter Balancer will only go down to .10oz. If these unbalance forces line up you could still potentially have .20oz residual on this Balancer. This is stated in the GM bulletin to take a Hunter Balancer out of "Smartweight mode". FYI Smartweight mode is a marketing term used to sell a shop on money they can save on wheel weight purchases without sacrificing Balancer quality. Unfortunately in the real world there are too many variables and the shop can potentially leave themselves open to come backs.
The Roadforce you mention with 16 and 19 lbs means there is run-out of .016" and .019" of an inch in the tire & wheel assembly. You can actually tell if you have a problem if you have a High Static number when you Balance. If run-out number creeps over 30 or Static number over 3oz then you could potentially feel that, especially if you combine it with a Smartweight balance.
Eliminating all vibrations (Static & Couple) is the best practice for best results. You can really feel a difference.
I got the "balance beads" with my new setup, no weights, smooth as glass.
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
