44 minutes ago, WT432 said:
I have a 2015 GMC Sierra 1500 Z71 4x4 Crew Cab all stock with 265/65 -18 inch Wheels/rims. I was wanting to raise or level out the truck, but still want a slight rake for payload. I don't want the front higher if i put anything in my bed. I have read many forums comparing the 2 inch RC in the front vs the 2.5 inch level RC changing the front and rear. The only discussions i have seen involve non z71 trucks.  For those who have a z71 truck which one do you prefer?
My plan was just to do the basic RC 2 inch level in the front and go with 285/65-18 tires, but would hate for the nose to be too high. Should I stick with my plan or go to the 2.5" or find a 1.5" level in the front. Thank you
Get measurements. I got the 2.5" and have only installed the front, it's a tad nose high but honestly I can't tell unless I pull a tape on it or if it's sitting just right. If you do the 2.5", put the rear block in. I'm gonna put mine in just to see what it looks like. This is on a 2014 Z71.
Edited by thutchi3
Just go with bilsteins at Max height. FHLH (user on here) has them with the exact tire size you're looking at and the truck looks great.
if you carry cargo on a regular basis and are worried about the payload weighing down your rear, the best option is airbags.
I've got an 18 Z71 and installed the Ready Lift 2.25" (left the back stock)and it's not nose high.  I think it looks great.  I've had a couple hundred lbs in the back and it didn't look noticeably nose high to me at all.  I'm sure if I load it up it likely would, but that's few and far between for me.
i would 100% agree here...these trucks are made as sturdy as the older 3/4 ton trucks (huge difference between my 2002 and my 2008...and now a big difference between my 2008 and my 2016...if you load the truck down so much that you are squatting this thing, and on a regular basis) i would almost say that would be worth a 3/4 ton, because you might be overloading it...i have loaded the hell out of my truck and you can tell, but it is pretty minimal...again, not like the older models...
but having said that...if you are that worried about it, like i said air bags would be your best bet, and probably cheaper than stepping up to a 3/4 ton!
Edited by spenpet
On 8/2/2017 at 9:09 PM, ducklawyer said:
2" with 285/55 ko2s
Will go higher next time
Would you go 285 60?
2" with 285/55 ko2s
On 3/15/2017 at 11:00 PM, woychc said:
Here's mine with 2.5" front and 3" rear blocks.
Do you have any rubbing issues? I currently have a 285 55 hankook on my truck and sometimes wish I had more tire. I have 2” leveling in front. That looks really good. How does it drive at 75-80 mph?
I installed a rough country 2.5 inch front and 2 inch rear blocks on my 2016 Z71.  I have stamped steel control arms and instructions said 3-4 hour install.  It took 3 people with vehicle on a lift 10 hours.  Biggest time consuming issue was getting the upper control arm to come loose on both sides.  In the end still worth it love how it looks and drives.  Running 275/65R20 tires (34 inch) on stock rims with zero rubbing and no trimming needed.
I have a 2017 Silverado 1500 with stamped steel control arms. Can I get away with a 2” level safely and not rip upper ball joints out? Ready lifts site makes it sound like I shouldn’t do any level or lift without changing my control arms.
My 2017 Silverado Z71 with 2 inch Rough Country front leveling kit.
Edited by Darthvader
Is this the lower strut spacer? Any clunks or anything when going over bumps? Also what size tires?
Yes, it is. No clunks at all. They are stock Z71 tires. 265/65/18
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
