so excited leveling kit is going on today 2.25 ready lift with upper control arms. They are also cutting the horse shoe looking mounts on the bottom of the frame while its on the lift. Next mod is the sdhq skid plate for valance delete.
Edited by Rally_18
On 10/4/2018 at 3:17 PM, Dirt-Rado said:
This is the Mazulla off road skid plate set up. Replaced the entire lower valance and they offered an optional tube front bar separately that I decided to go with (will have to paint or powder coat)
You can get from Kartek or SDHQ or mazulla directly. Big improvement. Couldn’t stand that valance.
are you local to mazulla? if not how bad was shipping on this?
Order from Kartek in Cali or SDHQ in Arizona. Shipping runs around $40 I think but I went straight to Kartek
sounds good i tried to email SDHQ but never heard back in far away and was hoping it was crazy on cost. I want the SDHQ skid cause it has the cutouts for the tow hooks and comes with the second skid for your front diff/oil pan
Call them. They get busy during the races as they’re always on site at tech with their employees.
will do thanks for your help are you happy with yours i kinda like the bar with the mazulla is it pretty solid?
Super happy. After I made a second skid for the oil pan haha
. I loved the front tube option so I went with mazulla. Install takes a bit but worth it in the end.
just ordered the one SDHQ makes with the tow hook cutouts now just to fab a front license plate mount up and wait for it to arrive.
What tires are you planning on running with that kit? Also, I see that you're in MD.  Who is doing the install.
In other news, did anyone see the pictures on the Readylift FB page a couple of weeks ago claiming that someone was running the 35x11.50 Ridge Grapplers on stock rims with no rubbing and only their 2.25" kit???
My plans are to ditch the 20’s and run 275/70/18 I’m thinking falken wildpeak at3w. I don’t want to do any trimming. Did that in my last truck and I kinda want to stick to an at and get the mileage out of it and still have some capability. I am in western Maryland and I have a friend who is the mechanic at global truck outfitter he did the install for me.
Congrats.
Or don’t run the front plate cause it takes away a lot of the cosmetic improvements you just paid a fortune for. I haven’t run one in 15yrs
Fix it ticks aren’t that bad here in Cali though.
On 8/25/2018 at 2:43 AM, Shredder15 said:
I had an add a leaf from a different company that was very good. It raised the rear 1 1/4”.
FYI, the front had a TGC 2.5” level in this pic. I eventually went to a 2” level and 1” rear block because I didn’t like the loss of factory ride and decreased range level of travel in the front at 2.5”. The increased clearance I ended up with is exactly what I wanted and I’m happy with the setup with the bigger LTZ stock wheels and tires.
Where did you get the rear block? It's really a 2" block to replace the factory block correct?
Got it from an off road store. Yes it’s a Readylift 2.25” block, which the salesperson referred to as a plus one.
so I just leveled the truck with 2.25 readylift and I'm starting to looking at wheels and tires for after winter. I'm thinking 285/70/17 Falken Wildpeak AT3W on Method Double Standards 17x8.5 0 offset. i want to run front flaps but I don't want to do any trimming unless its to the flap. Is anyone running anything similar that can get me some input. My second setup choice would be 275/70/18's just want to ditch the 20's need more tire and less wheel. Thanks
I’ve got the same 2.25” level, running Nitto Ridge Grapplers 285/60/20’s =34”. Barely rubs on the felt liner when backing up on incline. Anything taller will definitely rub fender edge requiring at least a lift.
Sent from above
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
