Bilstein leveling shocks up front for more budget oriented or my preferred billet aluminum front 2.25” top and lower strut mounts plus a 1” in rear. I prefer the aluminum billet spacers from 4wheelparts and then later buy Bilstein front and rear 5100’s. Reason I don’t like the leveling shock is cause you’re screwed if it goes out on you with larger tires but you’d be fine if the shock went out on you with installed billet aluminum spacers, just get new shocks. You’ve got the 14 model which doesn’t have the cursed new stamped steel UCA’s (upper control arms) that cause your tires to rub them.
Question on the bilsteins, I just ordered a front set last night to level my 14 gmc. Would you happen to know exactly how much "lift" I will get off of those alone? Will just the struts be enough or should I get a set of spacers and even out the lift by setting the struts on the middle height with the added spacers?
Sent from my SM-N950U using Tapatalk
It’s one or the other, never both. Max setting I believe is 2” - 2.25”. Just remember that mid 2015-2018 GM switched to stamp steel UCA’s which will definitely cause tire rubbing if you go to 33” tires. Leveling these year trucks with bigger tires requires new offset wheels too. Bora makes the best spacers but being your truck is new your warranty will be affected by spacers as soon as the dealer spots them. Funny thing is I heard you can go 33” without level and not rub. I’d recommend leaving it alone with just level and go from there, save up and get some nice +1 or 0 offset wheel and tire package.
Never both, what's the reasoning? In theory wouldn't the 5100s be basically the same as as your standard strut just with the ability to adjust the height? I'm unexperienced when it comes to suspension systems. Tire size isn't really my main concern, I just like and prefer the true level look. I have run spacers on a previous truck and the ride quality went to hell after. My truck sits like a 2wd and rides like a boat with the ranchos. I've heard alot of good about the bilsteins planting the truck to the ground and helping with body roll in corners. My 14 has the cast ucas but I'm planning on switching out for the cognito ucas here soon. I would just like to get my level situation figured out first. c00d58d6b42c4429c90cbd33dca0ba51.jpg
You can use the 5100s with a leveling kit, as long as the two don't exceed 2.5". Anything over that is too much angle for the suspension and CV shafts. Max lift from the 5100s is 1.85", according to bilstein. I ran 5100s set at the highest with a 1/4" home made space and it was fine. Gave me about 2 3/8" lift.
17 hours ago, SNAFU88 said:
It does BUT the top of the hood line is higher than the top of the bed line and it creates the illusion that the truck is nose high.  Especially when the truck is on even a very slight incline.
to each their own.  I was just stating facts.
17 hours ago, Tyy1907 said:
What brandc2" block did u go with?
No vibrations?
Rough Country blocks.
Only driven around town so far and it feels no different.  Going to get on the highway this weekend and test it out at high speeds.
As far as to much angle, what is the difference in buying the diff drop kit and new ucas if I wanted to raise over the 2.5" mark. Isn't that basically all the comes with a legit lift kit? (The smaller ones that is) The diff drop kit is 30 bucks from American trucks.
And my question about the spacer with the bilsteins, if the shocks wasn't set on the max lift wouldn't it ride a little better than being maxd out?
No worries, never do both, it’s one or the other and you should not go past 2.5” height, if you do you’ll put an enormous amount of stress on your UCA’s do to the angle and destroy your front suspension. Call the experts at 4wheelparts and ask them for a professional answer, if you want to get higher do a lift kit which is designed to lift without creating chaos on your suspension and comes with a differential drop kit too.
Anyone using the BDS leveling kit?  On their website they claim the it doesn't effect the suspension angles negatively. Is this true?
It must come with UCA’s and hopefully a diff drop if it’s over 2.5”-3”+
I had the 2" BDS leveling kit on my old 2015 lease with a Zone body lift.  I never experienced any issues with the kit although I only put 30k miles on it.  When I turned it in, there were no issues either with the dealer nor GM.
  • Thanks 1
It's 2" so wouldn't need UCA's correct?
You’re good, mine is a 2.25” and zero stress issues.
  • Thanks 1
I have a ‘14 4wd that I bought about a month ago. It appears to already have a leveling kit but there’s still a 2” difference with the front and rear. I’m wanting the truck to sit dead level. What size do I need for that? 2.25 or 2.5? Thanks
Post pictures of your existing level. You can't stack levels. Odds are, with that much rake, you've got extra height in the rear as well.
Options would be replace tall block with stock block in the rear, or replace the whole thing with a real lift.
Edited by MBSierra17
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
