I'm finally ready to level my truck out but wanted some info before I do.
My truck is a 2018 gmc sierra z71 SLT 4x4.
I was quoted $350 for a ready lift 2.5 level kit.
I want to use my stock wheels which are the 22x9 denali wheels and want to wrap them in some toyo at3 33x12.5r22 or nitto ridge grapplers in the same size. Will I have issues or is this setup good to go?
Edited by MANDINGO
You should be fine with that setup if you go with their upper control arms as well. If not the tires will rub the stamped steel stock upper control arms, any thing above stock size will rub. I have the same setup and I have their upper control arms, Stock size was 275/55/20, I wanted to run 275/60/20 which are 33s basically, just a little narrower. I did a ton of research and if you have the stamped steel upper control arms which most 2017s and 2018s have you need to change upper control arms. I have no complaints whatsoever with this set up, rides and drives great, I ran the 275/60/20s for a year no issues, just upgraded to 33x1250x20s today and no issues even with my new 20x10s. 22x9 with 33s will fit no problem with 2.25 level.
Installed my readylift 2.25" level and new upper control arms yesterday. Was fairly easy and I'm really happy with the new look.
My new wheels are waiting in the garage for my tires to come in some time this week. Ordered 285/70/17 Duratracs.
50104781546_635e6207cc_b.jpg20200711_092719 by Rob Malaguti, on Flickr
50104781081_4c24d95456_b.jpg20200711_210050 by Rob Malaguti, on Flickr
50104780526_5e9dc631b0_b.jpg20200711_210007 by Rob Malaguti, on Flickr
Nice which wheels and tires are you throwing on?
17 x 9 RTX Baja wheels with 0 offset (basically black method race wheel look -a-likes) and 285/70/17 Goodyear Wrangler Duratracs.
I’m running a 2” under strut level. Has anyone ran Bilsteins on top of that? I want to run them on a lower setting to get it a little closer to level.
2.25 Ready Lift
Zone add a leaf
285/60r20 Norcal Mod No Rubf1af57ab65756cf07d6475246bf15f22.jpgd805de75c0f2e7e4f1866c78e73db6a1.jpg
Nice! What's your wheel/offset? Got any stance pics?
Thanks!
Jon
Sent from my Pixel 4 XL using Tapatalk
Thanks!
Jon
Thanks Jon. The wheels are Black Rhino Kruger 20x9 0mm offset. I will share a few more pictures later this afternoon.
What size tires are you running? I wouldn’t run a stacked level (spacer + bilsteins)
275/70/18. Would you recommend going for 3.5” lift instead?
No those are basically a stacked leveling kit labeled as a lift kit. You’re either stuck at 2.5” with a leveling kit, or jump up to a drop bracket 4-4.5” kit (zone, cst, bds, etc)
Are you 4wd or 2wd?
Are you 4wd or 2wd?
I did not know that, thank you. I’ll probably just swap out the spacer and run Bilsteins.
I’m 4wd it’s 2016 LT z71
Yea with 4wd not many options to “do it right”.
I run Bilstein 5100s with a 2" Rugged Off Road spacer, but I left the shocks at the factory level and did not raise them using any of the notches.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
