05cae05a-b3fd-44ef-aca8-ab92da5cfa21_zps
Just added the Elite Engineering clean side separator to complement my catch can. The Airaid MIT uses 5/8" hoses and barbs so I bought a 5/8" heater bypass cap to block off one port on the
MIT tube. I also bought a brass barbed 3/8" to 5/8" fitting to adapt the separator's 3/8" inlet hose to the left over 5/8" Airaid hose. I ran the supplied 1/2" hose which connects each valve cover underneath my engine cover.
Your engine looks very nice. Is this the 5.3 or the 6.w? What have you all done to it? Headers? What is that plastic top cover from?
MJ,
Where did you get the 5.3L sticker on the front of the Caddy engine cover? Or is it molded into the cover?
That engine looks real nice. Good job!
Thanks
3,800 miles on the truck and the catch can was installed as soon as the truck got home from the dealership. The liquid is dark like oil, but it's very thin like water. No milky substance form oil/water mix at all. Not sure what exactly it's made of, but I'm glad it's not going through my intake
You'll start seeing more water in there as winter gets closer. Once the temps get below 40°F, you'll see more and more water.
Depending on where you live, you might not see much, but up here in MA, it'll be almost all water by January - or ice, I should say.
I just got my elite catch can this week, installed it yesterday morning. I used tape on my threads.
This is what I had in it this morning after about 80 miles (mostly shorter trips to town, temps between 30-50 outside)
I think I'm gonna need a bigger can for the winter....
Looks like oil to me. Vapors condensed in the can.
Drained the rx can on my car yesterday
Rob what plug wires are you running?
Ryan
Edited by RyanbabZ71
You'll be alright, so long as you keep up with it. My glass catch can holds maybe 4 oz. tops, and it gets to about halfway with mostly water (in cold weather - below 40°F) after a couple weeks of local driving.
Elite Catch Can with Check Valve arrived and will try to install this weekend, Do I need thread sealer?
It should have an o-ring around the top.
RT
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 684 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
