Did the lowering shackles and it's still 3/4" higher in the back. A Forum member suggested that I replace the stock spring block, which is 2.25" thick, with one that's 1/2" thick. That should take care of that. I ordered them yesterday so maybe I can get them on this week. It sucks to be anal:). Tapatalk via iPhone 5s
The factory is actually 1.257" thick, another member posted a picture of one with a caliper to measure its thickness :D
Did the lowering shackles and it's still 3/4" higher in the back. A Forum member suggested that I replace the stock spring block, which is 2.25" thick, with one that's 1/2" thick. That should take care of that. I ordered them yesterday so maybe I can get them on this week. It sucks to be anal:). Tapatalk via iPhone 5s The factory is actually 1.257" thick, another member posted a picture of one with a caliper to measure its thickness :D
I meant 1.25...DUHHHH :freak: . Tapatalk via iPhone 5s Edited by LTZTom
How hard are the drop shackles to install? Can it be done in a grage by one person with normal tools? What's the most difficult part?
Thanks.
I think the fuel tank needs to be dropped so the left can be pulled
Not true. Takes about an hour. Receiver hitch will need to come down to get bolt out on one side. Should take about 1-2 hours depending on how fast you work.
Post a good side pic and f/r measurements if you get yours done before me lol
And sorry man didn't read all the way. Wasn't meaning to come off as rude.
I got tired of jacking around with waiting for somebody to do my lowering blocks so I just did it myself today. Turned out GREAT. I'm attaching some pics for you below. The only thing I forgot to get for you was the front measurement but after looking at the pics you'll see it's PERFECT!! I'll be looking for pics of yours tomorrow!!
This is the rear measurement.
Edited by LTZTom
So you got a new block instead of shackles?
So you got a new block instead of shackles? Sent from my SM-N900V using Tapatalk
No. I got 2" shackles too but it was still about ¾" too high in the rear so I removed the factory block that was approximately 1¼" and replaced it with a ½" block to make up the difference. Now it's PERFECT!!!
No. I also have the 2" shackles but it was still about ¾" too high in the rear. Thanks to brentadams646 I found out about the blocks. I replaced the factory 1¼" with a ½" block and that made up the difference. Now it's perfect!
WHOOPS!!! I did this twice because I couldn't find the first one :freak: . DUHHHHHH!!
In that last pic, is the rear like super close to the bump stop???
I didn't notice it being too close. Maybe it's just an optical illusion. I drove it quite a bit after I got done and it rode just like it always did. We have "speed humps" in our neighborhood and didn't notice a bit of difference in negotiating those stupid things. It rides like it did the day I picked it up from the dealer. I just couldn't be happier. Thanks Brent!!!!!
Edited by LTZTom
Dude it looks perfect!!!!!! Mine goes to the shop tomorrow at 8am. Glad everything worked out just right! Take a hack saw with a blade for cutting steel (fine tooth) and saw off the bump stop at the first indention from the bottom. I've done it before.
And you're welcome man!
Edited by brentadams646
I need to cut my bump stops, plan on doing it once it warms up. Only bad about leveling the rear is it moves the shock up 2" into the valving range. I have found on hard dips the truck will blow thru the valving pretty quick and allow the rear end to bottom out and hit the bumps stops. I am waiting on Rancho to get the OEM specs for the shocks and see if they make a shock that will work with a leveled setup.
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
