If I go any lower I can't drive it. Already damn near ride the upper inner fender if I have more than one other person in the truck. LOL
I'm at 4.5 in my rc right now my front end sits so low because I have small tires. You might want to get a smaller tire. Which will give you mkre room in the fender but also lower the truck.
My front valance hates me though but I'm ok with that
Yeah. These are 29 inch tires in the front right now. Still have the stock 31 on the back. Doing 24s all the way around so I'm gonna end up clearancing the inner fenders some. I just ordered a 2 piece drive shaft conversion yesterday because I'm rubbing on the cross member on large bumps and I still want to go down another inch in back.
You either need to tub the front fenders of run a 25 series tire in maybe. Maybe squeeze a 30 series
I'm running 17s 28"tire front and 30 rear
Remember I told you about the tire getting pushed back into the fender well? Take a look at the inez k2 kits. They didn't even correct for that. That kit set at 4" is worse then your teuck set at 5. Ill pass on that inez kit. Most people don't look at things like that
I don't see that problem based on the pictures posted on the Inez Hotrods facebook page (see example picture below). I purchased their 3-5 kit (which I have not yet had installed). The main thing I liked about their system of replacing the control arms is that the alignment of the wheels stays true unlike using drop spindles.
20882393_166750353872579_856074399418406
When you lower using springs and or struts it changes the horizontal geonomtry. Look at the space between the front of the front wheel well and the rear of the front wheel well. It already started pushing it back
Even my 1" drop from a belltech strut moved my wheel back. Crappy side effect.
The upper arm is angled back some so as the suspension compresses, the wheel moves back. I think it makes for a better ride but it just looks like shit in my opinion
I'm limited on ways to lower a 4x4. There's no spindle that works on a 17 4x4 otherwise I would've done that with the djm arm
2015 Crew cab LT 4x4 with Mcgaughys 2/4 kit(34100). Just traded it for a 2wd so I could go as low as i want. This was my last pic, I'm gonna miss this one. post-161740-0-53326000-1507264278_thumb.png
2015 Crew cab LT 4x4 with Mcgaughys 2/4 kit(34100). Just traded it for a 2wd so I could go as low as i want. This was my last pic, I'm gonna miss this one. Screenshot_2017-10-06-00-27-04-1.png
You could have gone just as low with the 4wd but I prefer 2wd anyway
Not without way more work, money and wear.
Well not really. Only thing that's really different is the front cv shafts
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
