Does anyone tried these Belltech Lowering Shackles Part #:6401 or 6400 on 2017 2500/3500hd? I called them an they said they don't make shackles for 2500/3500hd just for 1500. :nonod: Can someone share a link for the right shackles for my truck. 2017 2500HD. Thanks
http://www.belltech.com/belltech-07-17-chevrolet-silverado-sierra-1-2-ton-all-2-or-3-rear-drop-6401.html
I'm limited on ways to lower a 4x4. There's no spindle that works on a 17 4x4 otherwise I would've done that with the djm arm
Inez is working on a setup for the 4wd Silverados. Started a few weeks ago on the design.
whats the difference between spindles from 2015 and 2017?
Probably size and shape to accommodate the axles and extra strength needed. I'm 2wd so not completely sure. The Inez kit will most likely be arm replacements but won't know for sure until they get put into production. I'm sure if you're near SE Texas you could drop by the shop and sneak a peak. :D
Chevy was not awesome and made 3 different spindle types. 07-16 (some 16s) have cast steel spindles. Some of those years also had aluminum spindles. From 16.5 on tbey went to a stamped steel arm and hd ball joint
I would love to be able to do that, unfortunately i am in Middle of Nowhere W.V. As soon as i say i want to lower my truck, people freak out.
:help::help:
What about shackles? Are they also different? Cant find one for 2017 2500hd 4x4 z71 :dunno::banghead::fume:
I would call the shop and ask. They do custom arms, blocks and shackles.
Edited by Goinovr
Finally got the Sierra Denali lowered with DJM 3/5 kit.
Lowered control arms in the front and flip kit in the rear.
26"x10" +31 offset GMC Sierra wheels.
Borla ProXS dual exhaust 3.5" oval tips out the sides.
Recon black with LED halo headlight.
LED tailight, LED 3rd brake light.
LED fog lights (on order).
Blacked out GMC grille emblem. Rear emblem not installed yet.
Working on component speakers/sub box/amp/DSP install next.
Edited by Denali2low
IHC just posted a 4x4 silverado with their 4/6 kit. Guess there is no difference in arms since it's the same as the 2wd kit.
FB post...
22365230_1451523268270160_85471850852501
Edited by Goinovr
I wanted to chime in here as well.
2014 Silverado DCSB LT Z71 4WD.
Really wanting to lower it at some point. I've looked at every possible kit for these trucks and just not sure where to go with it mainly because of the fact that it's 4WD. I know there's companies out there making stuff for the truck, but when you're like me and have never done suspension work or even lowered a pickup before, things can get a tiny bit overwhelming pretty quickly.
I planned on starting out on either an easy 2/3 drop (while upgrading shocks and struts since the ranchos have 70K+ miles on them now) to get a feel for how I'd like having the truck lowered, and possibly going to a 3/5 or 4/6, but biggest things I'm concerned about are the driveshafts and CV axles (All of which really ought to be upgraded since I would like to go faster, but that's a different topic for a different area of the forum) and pinion angles, etc. All that fun stuff.
Am I really making it out to be that hard in my head, or is there honestly more to it?
Forgive me if this has been long since discussed. Trying to dig through 106 pages of posts is going to get tiring quick. So, I do apologize if it's been discussed. I figured it'd be easier to reply here rather than start a new thread.
    • if you want a short turning radius get a short bed Colorado!
    • that is pretty awesome MPG there!  I think so far one observation is these trucks do way better on MPG under 65mph vs 70+ and they really suffer at 75+   I noticed on the stretches into NE on 76 and 80 which is posted 75MPH and I was doing 82 I was getting more like 13.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
