Yes and is it a rc or cc?
Mine is a rc. Truck is fighting me a bit today, getting the caltracs installed, but I'll get those pics for you as soon as I can put the weight of the truck on the axle
Are you at a 4/6? I havent seen your truck
7 hours ago, Nasty said:
Can you get me a quick picture.  I need to see the distance between your frame and axle pad in the rear. If you can hold a tape .measure in there that would be even better
Is this what you need? Sorry, it's sideways DSC_0811.thumb.JPG.80a16c7288b8f4fbb937d2f21fc41413.JPG
He posted it on the previous page :lol:
I was at 4/5, but once I get the truck back on the ground, I'll be at 4/6.f5768463c11f6a95f587946c13f213e3.jpg
That's at 5.  I'd you can do the same at 6 that would be perfect. Becsuse I might lift mine from 7to 6 in the rear
Thank you! My truck is a 4x4 so I had to do it a little different than most guys with 2wd trucks. I have 2" spindles with stock shocks and 2" lowering springs up front, and a flip kit in the rear set at 5 in that pic but next week I'll be bringing the rear to 6".
I had to do the same thing on my ‘16 CC Lovelessjl due to having 4WD... I currently sit at 4/7 based on my measurements from the ground... I used MaxTrac everything with the same setup you did...d80c762a4754682c3310a296a0454787.jpeg
Are you doing to notch it? I'm at 4/7 in my rc and I almost need a notch.  Cc sit lower than rc
No issues with my setup so I’m not gonna notch it... My flip kit is set at 5” but I had my blocks removed so I’m between 6”-7” in the rear...
Here is frame to pad, without a bump stop with the flip kit set at 6"a2bdfb7f65e882cdd4e3448c65f7462e.jpg
I’ll have mine on a lift on Thursday so I’ll measure mine as well...
1 more measurement while you're at it  center of hub to the fender. In the rear please.    I think I'm lifting mine to 6
this makes me want to got to 6'' since it's only 1/2'' difference in height.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
