had a question, hopefully someone here can answer it.  Lowered my truck about a month ago using the crown suspension 2/4 kit.  i recently noticed that now i have a clunking noise/sound coming from the front drivers side. i notice it more when driving slow and go over little bumps in the road.   took it back to the shop and the checked the every nut and bolt in the front to make sure they were tight.  they mentioned that it could be shock the is bad and might have to get replaced.  what do you guys think. my truck only has 24k miles.
Are you sure it's not the driveshaft? I had a clunk to and it ended up being the driveshaft.   I had to grease it
No, it's not the driveshaft, noise is coming from the front. My previous driveshaft issue was fixed.
Maybe a long shot but any of you pull anything remotely heavy after lowering? I'm trying to find a decent ball mount for my receiver that doesn't have a ton of drop on it
I towed wifes chevelle with my RC 4/7 drop but I had helper bags
I've only done shackles and pulled the blocks to level the rear out. I'm just worried about my old drop receiver mount getting too close to the ground
I had the stock reciever on.   I pulled it off.    Because I dont use it to do anything other than drive it now
Yeah this caught me off guard. I had plans for helper bags later this year or early next year
Mcg helpers are 350. And bolt in. No drilling.
Oooooweeee that's who makes my shackles. I was checking it some riderites but Ill check them out
On 2018-04-28 at 11:20 AM, Nasty said:
Do your self a favor and just do a 6 in the back.  Return the control arms for struts and spindles
On 2018-04-28 at 1:49 PM, lovelessjl said:
I have a 4wd 2016 RCSB. My truck is lowered 4/6 with spindles and springs up front, the spindles are part number 34204 from mcgaughys, and I used maxtrac 2" springs, then a flip kit in the rear. Love driving this truck around.
34204 comes with an Upper Arm but a bit expensive pair just to achieve just that 2”drop. Then still has to get a Strut for the additional 1-2” drop.
Seems the 2” drop Spindle  and  2” drop Spring is the more practical route but may I know what are the issues that comes with it, like alignment perhaps?
I have had 2 issues, one is a fairly simple fix, the other seems to have no immediate effect on handling or operation, but we'll see how it goes in the long term.
The first issue is cv clearance. The cv boot expands at highway speeds, and wore a hole in the boot and making a big greasy mess. But after figuring out what the issue was, it was pretty easy to do a little grinding and create the clearance needed. For the price of the spindles, this should not be an issue, however mcgaughys recommends no more than 2" of drop on a 4x4, and with the springs I'm at 4". So I knowingly exceeded the recommended drop, thus I can't really fault them there, just an adjustment to account for the extra drop. The photo is where the clearance issue was before fixing it.
The second issue is in alignment. The caster is slightly out of spec, while toe in and camber are well within tolerance. That being said, the truck drives and tracks straight, handles fantastic in the curves. If I didn't have the alignment sheet for the shop, I would never know it was out of spec. It may cause some long term tire wear, however in daily driving, it's not an issue. 941c129a9766754cfe188e023131ef09.jpg
I should check my boots,  I took a trip to Maine a few weeks back and spent a few hours on the highway
And higher caster isn't necessarily a bad thing, I wouldn't worry about it
It's definitely something I would take a peek at, but for me at least it was an easy fix.
    • I imagine the cold winters up here with repeated short runs in town every day for those that live and work in town and given what I have come to learn on this forum with DI engines having fuel dilution issues, and if they don't change the oil until it says to but keep driving it for a while, I bet all that is just lovely on those finicky lifters.
    • I just did some reading and Stabilitrak is more than a what I had originally thought. It is more of a vehicle control system to help the driver in precarious situations. I thought it was only the AWD system. Now I know. So I changed the title for this thread to AWD conversion to Z71
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
