Question, what Is the nut size of the lower ball joint as well as the size of that big nut on the axle?
Big nut on the axle?
Drive shaft Center hub I mean, lol...was it 177?
Just to inform of my findings. To get that last inch I desired on my McGaughys rear flip kit, I was able to use their GM short shackle. This was used in conjunction with their adjustable spring hanger. This will get you back the inch you lose when you trade out your stock hanger and use theirs. I have put 180 miles on this new setup and it rides perfectly. No binding, clunking, or squeeking. The shackles clear the spring and the hanger just fine. Ride quality is great, no change from stock shackles. Others might have a problem if you still have your stock hangers equipped. These shackles are specifically designed to work paired to their adjustable hangers. All in all, if your looking for maximum drop from your flip kit, just leave your stock hangers on. Looking back, that's what I should have done. Now the truck is sitting exactly where I wanted it to be.
Edited by 6ftdwn57
I had all 3  rands of those. They all went in the trash.  There was hardly any suspension movement
I'll try and do some launches from a stop on my way home from work today, and check out how it feels. But as for normal driving(bumps, potholes, dips, etc.) seems to be working very well. No complaints.
So after I did the flip, just in time my brother came by, he told me there’s a play on the rear axle. Woah! Is this normal? I was concerned coz i don’t have any idea about this end-play thing. Need your expert opinion guys. Tnxs
What is "a play"?
5 minutes ago, Nasty said:
What is "a play"?
With no tire, I hold the rear hub and push/pull it. The axle moves about 1/8” in and out
Normal
8 minutes ago, Nasty said:
Normal
What worries me at first was when I tried replicating it with our crew cab, I didn’t notice any movement. So, it’s normal, huh. Tnxs as always.
Edited by 204-WPG
you'd be surprised how many people come into the dealership and complain about this.
So does anyone have a experience on how the ride is with a drop  and helper bags?  I am considering a 2-3" drop in the rear (shackle and/or spacer) and adding helper bags for when I tow larger loads.  Front is stock right now.  My goal would be to keep it relatively level, but I just don't want to sacrifice the ride.  I have the  4x4 z71 offroad package with the stock Ranchos in the rear.
I was looking at Air Ride helpers, but wasn't sure what to look for in shackles.  Any suggestions would be helpful, thanks!
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 695 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
