17 minutes ago, 17gmclowlow said:
Yeah, I called had another talk with belltech. They say the flip kit comes with this shackle because the flip kit drops u 7.5" and u need this to bring you to the correct height. I'm going to use my oem shackle and see where it sets me. I dont teust belltech any longer. And then I'll be stuck with a shackle I paid 77 bucks for w shipping. Cause they charge 25% restocking fee plus require you to pay for shipping. I'll end up selling it for a loss if I dont use it. Thanks for your input boss
Ill find kine and send them to you if you want. I just have to find them
42 minutes ago, Nasty said:
I have those shackles in my stash. Tbey are 2.5 eye to eye. Belltech is dumb as shit. Same size as every other 1" lift shackle
I have my oem shackles on the truck now. And my oem hangers just came in today (sitting in the back seat) I'm just upset they told me I needed those shackles when I didnt.
These new shackles are 2.5" eye to eye. That's 2" shorter than the oem shackles. If I keep using the lift hangers which entales keeping the shackles flipped (shorter means drop apposed to oem hanger and longer shackles being drop) will I still get the drop I want? I mean I'm thinking about it in my head. AND technically it should work right? My front end is currently 2" lower than my rear. This should do the trick and I'll be able to return my oem hangers and save 244 bucks. Or am I off on my thinking?
Edited by 17gmclowlow
Eh, I already spent the money. Might as do it right. Lol thanks again for all the help.
On 10/2/2018 at 8:26 AM, qwank said:
All 2018 are stamped steel.
Thanks for that info.  Anything else that I would need to know in order to run that kit?  Better kits out there?
You should be fine with Belltech or McGaughy's stuff
Changed out the lift belltech hangers with oem equipment and looks much better. Next for the notch. Damn that's close. Thank God for bump stops. Never thought the pumpkin would be so close to the bed either.
Twisted metal works notch.  The end
I was looking at reklez. Do u have a link for the twisted metal. I just tried to look it up and I didnt find anything on c-notches. Just like home stuff. Railing and stuff
This is what i have. You can buy just the notch but why not get rear shock relocation as well
https://www.twistedmetalworkz.com/collections/notches/products/2008-2018-silverado-sierra-underbed-notch-with-shock-relocation-kit
I agree completely.  I dropped 1" in the rear. But I'm still 1" taller than the front. So after notch and shock relocation I'll buy a longer shock. Then worry about the pumpkin clearing. Thank you for that link btw.
By the way he does a package deal with viking shocks.  Im getting their front coilover kit as well.
i have the reklez notch and i was really impressed when i installed it. fit amazing.
very interested in this. once you have them installed love to hear how they perform.
2 minutes ago, maxpower98 said:
this is a picture of mine once i welded it all in. the fit on the frame was very tight.
Looks great
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
