LED Fog Bulbs & Lights
OUSux
Hey, how did you mount the light to the metal structure so you can adjust the angle of the lights?
I have these same mounts holding my Dually pods in place. The mounts don't leave a whole lot of space for adjustment but there is still some adjustment capability. You can push the pods in or out and do a little adjusting the aim left to right. Maybe a couple degrees up and down. Maybe 5 degrees each way (5 up and 5 down; left and right have about the same but a tad bit more)
  • Replies 637
So are you going to keep these dot fogs in or going back to the D2's? Could you aim the D2's down a little and get away with them?
I'm going to keep the DOT lights where they are for now. This summer when I finally get my lift, I will move the DOT lights back to being under the bumper. Only because that way they will be lower and as close to the ground as I can get them.
I will likely wire them so that they activate when the headlights are turned on and I will wire the D2s back into the fog lights. Still not 100% sure yet though.
I made a bracket which allows the rigid mount to bolt on, and can rotate and tilt the fog lights to aim them. I have them aimed up and out a bit, gets rid of any bright "hot spots" on the roadway. Lights a long way off, and to the side of the road as well. Not something to have on around others, but great for seeing deer as well as brush / trees when I'm off road. I used them to light up a work area at night earlier this week - very happy with them.
Anybody have a suggestion for the best match LED plug and play fog light bulb to a 5000K HID headlight ? Just looking for the closest color match to my HID's. Thanks.
Get away with running them around town? Why? If they're just being used for profiling around, any LED power will be fine.
I came across a Tundra ricer a couple days ago, going the opposite direction in town. His friggin lights were blinding me and everyone else a block away or more. He had HID headlights around 8000k and a HID foglight about the same hue of purple. Seemed like he had about 10,000-12,000 lumens pointing at me. Inconsiderate CS. But he looked really cool. 29_3_15.gif I hope the turd stops for a couple beers on the way home from work and he gets stopped for the lights and popped for a DUI.
Those people annoy me too.
If you have fogs with a proper beam pattern which are properly aimed you won't bother anybody except in hilly terrain. The fog cuttoff should be parallel or below (SAE spec is actually below) the cutoff of your low beams so your lows (even properly aimed) are going to shine in peoples eyes much more often than the fogs will.
Have an issue with the VLED 3000LM lights in my fogs. Good news is it's not a system main part problem. The 5202 adapters are the only issue. The one that adapts the LED to the housing is a little flimsy, but to able to use. The harness adapter is a more serious issue as it has one of my lights not working right now. I'll be calling VLED tomorrow.
20150127 200834
here are the ridgid D2's in the ridgid mounts. finally talked them into putting some in the trucks on the lot and this one sold the same day it wnet out.... these things are outrageously bright. i cant wait to do some of the DOT/SAE ones
Truck looks great! Is that a levelling kit or just bigger, more aggresive tires?
go check out the thread for the DOT pods, I got them on my truck and am really liking them! They don't compare to the D2 Driving pods but they are great on road pods :)
http://www.gm-trucks.com/forums/topic/168523-rigid-fog-lights-d-series-dotsae-certified/
truck is leveled with 2.5in ready lift. the tires are stock sized but BFG 2's. I talked to the managers at my dealer and i think we are going to start doing this combo on all terrains that come in.
I am looking for the best wat to power up my new factory fog lights.
I have different bulbs in lieu of the Factory ones.
2014 GMC 1500 new body style. I would like to buy a factory wire loom and switch.
Then I would have to go to the dealer to have the BCM programed if they would program it.
I think this may cost more then I want to invest,
So what other way can I power them up.? I was also thinking to put a switch into the cab.
But that's not exactly a perfect solution.they could be powered up by tapping
Into the headlights, but you can't turn them off unless the headlights lights are off too.
I think if I got power from the parking lights they would be on all the time as well.
what is the most popular way some of you folks are powering up new fogs you have installed?
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
