Thanks Jon. I took the plunge and ordered the AFE.
Good thing you did .. I emailed S&B again and they are now looking at a LATE September release. Maybe they will have one out by the end of the year at this rate :shakehead:
What are the benefits of buying a CAI system with a dry filter versus an oiled filter?
Same question.
Sent from my iPhone
I have the AFE Momentum GT Stage-2 with the dry filter and like it a lot. Data logging shows it should be worth a significant bump in power.
this really looks like a nice set up, i'd love to see the dyno on teh numbers if they did in fact come close to those numbers
Are they ever going too make the mit for our trucks?
Check out the Airaid MIT. The truck already has a CAI, you just need the tube and a lower restriction filter to get the same benefits as a $300 CAI. Any HP or MPG gains are marginal at best though. If you check the data, most CAI "performance improvements" happen at 5,000 rpm or above.
FYI.....you're in the 2014 section.....the Airaid MIT isn't available for the 2014 yet.
I installed the AFE momentum stage 2 with dry filter last night....OMG. It's like it woke the 6.2L up and unleashed more ponys. Great sound too.
Same question.
Sent from my iPhone
With the older engines the oiled filters were okay but I've found with the new engines the MAF sensors are more sensitive and the oiled filters tend to mess with their readings so most people I know are switching over to the dry filter systems.
I would also avoid them in a direct injection engine as they already tend to burp up a small amount of oil already into the intake.
So that's my opinion older engines ok new engines avoid.
NO PICS!! IT DID NOT HAPPEN.!!! DUH!!!
I'm so torn on which CAI to get haha. They all seem very close. I spend more time reading these darn threads only confusing myself even further haha
Is there any down side to installing a CAI?
Edit: never mind, I see my question was already answered.
Edited by 14LTZZ71
I had a vibration with my AFE Momentum Stage 2....Ran two large zip ties over it and it now has been great. Much much happier w/o the vibration.
Where was the cai vibrating ?
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
