1 hour ago, Slabsides45 said:
I recently got the Fold-A-Cover G4 Elite along with the Personal Caddy storage unit.  I chose this setup because I could go from my old tool box to this unit, move all my toolbox stuff to the Personal Caddy, and then access it through the front access without having to flip the whole thing up to get to my tools.  I can still fold the rear of the bed up to expose as much of the bed as I had available back when the toolbox was there, but now it stays dry and secure the rest of the time.  Happy customer so far!
https://www.foldacover.com/products/tonneau-covers/g4-elite-fold-a-cover/
I bought the personal caddy too but ended up removing it after a week or so, it's been sitting in my garage since, I can't seem to be able to sell it lol
I can promise you, had I been able to locate one for sale used, I'd have been all over it.  May I ask, why did you remove it?  For my purposes, it takes up about the same room as the previous aluminum toolbox did, though it has slightly less room and sits deeper.
I needed to load something in the bed that wouldn't fit if I hadn't removed it, and I just never got around to putting it back
Installed the Bak Revolver x4 on my Slivi today.  Seems like a really nice unit, installation was pretty simple.   My only complaint was one side of the cover was not packaged correctly and the left hand seal was slightly damaged (though nothing that affects function).
Installed the bedrug liner and Undercver Ultra Flex.  Don't mind the little one and the screw drivers in the tie down anchors, he turns my bed into a fort once I installed everything.  I ened up installing the LED light strip and tool bag, I can always pull them off if I don't like them...just wanted to try them out since it was included with the cover.
Edited by shadrickjm
1 hour ago, TruckDaddy said:
If you bought your Undercover Ultra Flex on 3-1-18 or after (through 3-31-18), there's a $75 rebate.
Damn...............just missed it.  I just checked my order dat and it was 02/26.
Just got a truck after two years without one.  Not sure how I lived with out for two years.  I want to get a cover for the bed.  Have ben looking and there are
so many on the market and so many manufactures.  After ruling out some of each and deciding about what I want, the price of the remaining on the list is
more than I'm willing to pay.  I'll try to describe what I'd like and the top contenders. Would love some alternatives to research.
1) I don't like soft covers because most all I've seen flop or wave at higher speeds and that would drive me nuts.
2) I like folding covers that the last position doesn't block the rear window, and are easy to remove when needed.
3) Must be good with water management.  Will carry luggage often.
Short List:
Extang Encore
Extang Solid Fold
Fold-a-Cover G4
So any recommendations of alternatives to these at a better price point is greatly appreciated.
Those diamondbacks have really gone up in price since I was looking a year ago
Just ordered a Bakflip MX4.  I'll post up again once it arrives and I get it installed.  I liked the MX4 because it's 4 section.  Makes it shorter and more open bed when all but the last section is open plus it doesn't block the cargo light when all the way open.  I also looked at the x4 revolver, but I was concerned with the longevity of the vinyl on it in the Colorado sun.  At least withe MX4, I can put wax on the powder coated panels to try and keep them from fading out.  Tonneau  cover world is having a sale so the price was better right now.
Edited by Mike GMC
What’s up everyone just wanted to throw my .02 in. I was looking for a tonneau cover for weeks. Yeah, I’m picky... I was looking for a low profile roll up tonneau cover that wouldn’t break the bank but also had the look I was after. I finally found what I wanted it’s a ProZ lo roll cover which was reasonably priced at $249 and eventually got a 15% coupon for dropping it down to $212. Much to my surprise this thing was shipped out of a Truxedo wharehouse. The same truxedo low profile tonneau was nearly $75 more.
On 10/31/2017 at 9:26 AM, crewl1 said:
2 years later my Extang Solid Fold 2.0 that I bought for my 6.5 foot CC is still going strong.
Cons:
The pebbly finish has turned slightly duller as I don't do anything special to protect it in the hot So Cal sun.
 Slight valleys have appeared under the front clamp locations. (They say don't over tighten to avoid this but tight enough to hold will cause it.)
Cover is not completely water tight as it gets small leaks during rare heavy downpours around the first fold area. Been this way from the start and I expect any folding cover will get leaks.
Pros:
Easy to remove and replace by one person.
When the cover is removed there are no rails in the way, you get full bed access.
Very light weight to open and close.
Overall I am pleased with the investment.
The quality of the cover predicts it should last a few more years.
Even with the extreme sun, heat and UV exposure we get here the rubber parts are still soft and pliable and all other components seem to be holding up well.
Coming from a solid fiberglass cover on my previous truck I am grateful not to have to ask for help to remove it,  or having to  keep the lid tilted up in the air when I needed to carry something taller than the bed sides.
https://www.extang.com/p-36824-solid-fold-2-0.html
Any other Tonneau covers you were considering? I am in southwest sun with occasional downpours. Looking for one that is easy to remove if i want to load my dirt bike but strong and secure if I am traveling and am storing stuff in the bed.
Where did you buy it at?
Sent from my SAMSUNG-SM-N920A using Tapatalk
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
