I stumbled on this website. It has the RPO codes and descriptions. Also has lots of other useful info for those wanting to order their trucks.
http://www.gmfleetorderguide.com/NASApp/domestic/proddesc.jsp?year=2014&regionID=1&divisionID=2&type=0&vehicleID=14683&section=modelhome&page=&butID=1
Here is the reference sites for Chevy and GMC just select which one you need. Once you click Chevy or GMC in the box at the top right lets you pick the models you need.
http://www.gmfleetorderguide.com/NASApp/domestic/brandsel.jsp?year=2014&regionID=1
Edited by Blue Sierra Owner
  • Like 4
  • 3 months later...
Interesting, the RPO codes for the L86 6.2 engine clearly read that, among other things, the engine is "E85 Max".
This coding is the same as what is referenced for the L83 5.3 and the 6 cyl engine. Those codes also state that, among other things, the engines are "E85 Max".
The inclusion of the "E85 Max" information for the 6.2 is at variance to everything else which is published about the 6.2. Anyone have insight as to why?
  • 4 months later...
I'm new here and I'm not sure where to ask for help.
I have a 2004 GMC 1500 Sierra 2wd.
Extended cab, 5.3l v8, automatic.
The drivers bucket sags really bad. I feel like I'm going to have to look under the steering wheel to drive it.
My truck has not quite 56,000 miles on it.
It still has the original serpentine belt, spark plugs, disc pads, etc.
It has never had anything heavier than ice chest in the bed.
I need to get something to lift the rear of the bucket UP.
I had found a kit that installs between the floor and the bucket seat frame but I cant find it again.
Anyone have an inexpensive fix as I'm 63 and on disability.
Thank you for your time.
  • 6 months later...
Not all the codes in my glove box are on that list?
I sent a PM to GM Customer Service with my email and VIN and they sent me a build sheet for my truck. It included the RPO codes that matter. There is also a web site where you can look up individual codes...
http://www.rpocodes.com
Thanks!
Visited the website that you posted, and still cannot locate a bunch of the codes for my truck. Is there a difference depending one when the truck was built in the model year? Just curious, not terribly worried, but just wondering why they would not have all the codes published.
Where did you send a PM to GM to get a build sheet? I just picked up a new 2015 Sierra SLT All Terrain 4X4 and it would be neat to have a build sheet. Is it a complete list?
Thanks,
Thanks,
Literally, send a PM to GM Customer Service...click on the link below and then "Send me a message". Yes, it is everything from my build sheet. Send them your name, email address and VIN...
http://www.gm-trucks.com/forums/user/92340-gm-customer-service/
Edited by chuckl1218
  • 6 months later...
Not sure if I am in the right place but I was curious if anyone knew a sight where I could type in a vin code to find out what dealership a truck is at? I have a membership to Carfax, tried that... it just came back "NEW CAR, CLEAN"... But what I am really wanting to know is what dealership has the vehicle.
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
    • Just pull the inside door handle.  It has mechanical override to the lock.
    • Got to have those sliding doors. One of my favorite things about a minivan. The Kia does a good job of making a minivan look like an SUV. I may do a Toyota next. I want the awd option.
    • I took my 24 Sierra Denali 4wd in at 37,000 miles. Had the mileage maintenance checks done, asked them to change out the two limited slip differentials, including the limited slip additive, and change out the transfer case fluid. They rotated my tires, verified my shocks weren’t leaking, and whatever minor checkouts that were on the list for 37,000 miles. About three hours later, they charged me $600 and sent me off. I was considering having the 10-speed transmission serviced, but between the posts on this forum and previous experiences with transmission failures after a fluid and filter change, I decided against the tranny fluid changeout when the service advisor told me it would take about 3 hours and cost about $500. After growing up working in three different full-service gas stations, I know to stay far away from flushing machines connected to any automatic transmission. I don’t meet the severe duty schedule, but I may follow the 45,000 mile tranny service, unless  i see more problems from doing so on the forums. I expect I will want to watch the entire procedure. The various utube videos do a decent job of showing how much time and attention should be taken for a correct fluid &filter replacement, so witnessing the procedure seems something I should do. Trust but Verify🥳 Otherwise, I’ll follow the owner’s manual recommendations, whatever they are.
