Had a gear swap done today went from 3.42's to 4.10's. Happy with the feel so far, but still awaiting on tune update, and trying to take it easy on break-in
are the new gears Yukons? I'm interested in doing this when I lift my truck. Also, is this something the dealer can flash into the onboard computer or do we have to go aftermarket tuning only? thx
AAM. I believe the only way to update the computer is aftermarket as 4.10's are not a factory option on the 1500's.
Edited by SgtShiv
Added my step bar leds today. Tied them I to the dome lights so they come on anytime the dome lights are one. Works great with the key fob unlock and such.
Edited by mjdxtreme
That is definitely a cool mod.
When I added my hid's I had to shut the exterior lights off so I would not burn out the ballasts with the on off cycling of them. So figured after reading others on adding footwell lighting and assist lighting. Figured it would be the perfect mod for adding light while in dark parking lots and such. Works great and for like $70 bucks and an hour in my garage. They turned out great and put out tons of light.
Edited by mjdxtreme
Very nice... Would love to do that mod. Any chance you can provide a first time truck owner the write up on how to do this.? TIA
Sent from my SGS7
Sent from my SGS7
I cannot take credit for figure this mod out. There are several members who have done similar mods and I used the great info that they provided. Here is a link to where I got some of info to complete.
http://www.gm-trucks.com/forums/topic/172674-footfootwell-lighting-color-match-wiring/
This is just one place. There are several other links as well.
Thanks brother
Sent from my SGS7
Installed Pop & Lock and readjusted tonneau cover, wasn't quite right after bed liner install.
What lights did you use? Looks great!!
I cannot remember the brand. My brother found some on ebay. They were a set of two 5 ft long strip of led lights with a rubberized coating. 3m tapes to hold under the rockers. I can get a closer shot of them if you need me to. We ran the wires through the rubber grommet on the drivers side that the e brake cable goes through. And on the passenger side there is a plastic plug we drilled a small hole in then used silicone to ensure the hole was fully sealed. Snaked the wires under the carpet and behind the dash to the wiring harness that controls the dome lights.
Put her in a ditch over the weekend
bad weekend. are you ok ??
rdnckhntr94
Sorry that happened. Did you shear the bumper? Surprised it would break off like that.
Edit...I see now that the bumper bent and the cover lifted making it look broken off.
Edited by DAY11
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
