What brand catch can? Or is a diy?
Do you remember the parts used. I have the HD catch can right now but want something better and a little bigger but I can't bring myself to drop 200 bucks. What type of can Didi you use and did you baffle the inside?
Sent from my Nexus 6P using Tapatalk
I machined it myself. It has a compartment in the lid filled with stainless mesh similar to the Moroso can.
9744E749-7A27-46D3-A7CC-97483530245A_zps
921F372F-8D5E-4C45-A16D-87A51819644B_zps
I traded my '14 LTZ for a '17 All Terrain and absolutely love this truck. I'm not good with adjusting photos and I've been swamped with holiday clean up so I only have one picture of the new truck. Hoping the weather clears out and I will get some pictures with the sun out.
  • Like 5
Congrats! What was the purpose of the trade?
-tapa
-tapa
Thanks. My '14 was staring to have some issues (Passenger and rear seat rattling still rattled after adding foam to it, electrical issue and out of warranty) and had great rates from my credit union. I do outside sells for construction equipment and drive about 1000 miles a week.
Nice work.
-tapa
Trimmed the carpet liners. Really didn't want to zip tie it back. Problem solved. I circled where it was rubbing.
Sent from my Nexus 6 using Tapatalk
Swapped third brake and cargo bulbs for Phillips LEDs. Added a drain valve to my catch can. I drove about 30 miles today and the can caught about a tablespoon of mostly water.
Changed U joints. And found out that the parts store doesn't list a part number for the u joint at the axle. There are 2 different sized u joints for the steel driveline. Had to match one up with their stock.
Sent from my Pixel XL using Tapatalk
Bad u joint already? How many miles?
I've never had good luck finding u joints for my GM trucks at a parts store, I typically get a OEM Spicer (if my memory is correct) from the dealer. Little bit more but fits perfectly every single time
Sent from my SM-N920V using Tapatalk
Just trying to narrow down my chevy shake. But I have 60k Miles. Next step is a driveline balance. Anyway the u joints felt really gritty so didn't hurt to change them.
Hmm I got 67k and I tow a lot, maybe I should check them next time I have it up for a tire rotation.
Did it help at all with the shake or you haven't driven it yet?
Thanks! It's a double row 24 " curved. It works good, it's really bright.
Here's a wall shot of just the bar.
Oh its a double row. I was just going to go with a single row since this particular grille has the thick pieces figured it would block one of the entire rows of lights.
Thanks for the feedback i may reconsider now. Do you have any pics with the grille off when you were mounting it?
Sent from my SAMSUNG-SM-N910A using Tapatalk
They are easy mount. When you take out the grille there is a lip on the inside wide enough to mount it.
When it's on at night you can't see the bars. Here's a pic of it on.
Interesting so you have it mounted on the actual grille. I was thinking it was on those support braces like most others have light bars
3fb354df96111e656327baca7a92ea99.jpgd8b459cbea93e90d133b7d2a874f5647.jpg6c3093247c73fdc8d1cd90c98adb1429.jpg7c70b4a402bd6cdef808d1b3fda07295.jpg7af773a72c873b7cac1bfeb9c46bfc7d.jpg
$13 JDM from ebay for my Cargo lamps and bammm they light up the garage quite well. These LEDS are awesome.
Edited by asalinasz39
    jl6690506
    jl6690506
  • Who's Online   2 Members, 0 Anonymous, 1,113 Guests (See full list)
