On 6/11/2018 at 7:45 PM, MHPrior80 said:
Still jealous of this cluster!!
I was about to say, "I'm actually more jealous that he has all four tires reading the same pressure!"
But then I noticed the 33.
About a week ago I slid into another truck on a wet road doing about 10 - 15 mph if that. Only damage to my truck was at the point in the front, rubbed off some paint and maybe a few scratches but nothing too noticeable. Did more damage to his door.
Chevy vs. GMC for ya!!    <joking>!!! LOL
  • Haha 1
22 hours ago, Zrodie21 said:
Talked with one of the guys from Randy’s ring and pinion and they advised either 4.56 or 4.88 due to my lift be a total of 12 inches and my tires are 37s with the 24 inch rims making each tire/wheel combo be about 100lbs each. They said the 4.56 will be close to stock and the 4.88s would be for a better experience and have that get up and go
I'd be surprised if they're only around 100# each. My stock 20" with p-rated 33" tires are just over 90. My stock 18" wheels with worn out 265/65 SR-A's are almost 30# lighter each ! I can definitely feel the difference.
Edited by michigan2500hd
Wording
Yeah I'm not exactly sure but when picking them up I kinda quesstimated lol
LOL K2 vs NNBS is the real story here.
  • Haha 1
Finally got to wash my truck only to see the weather forecast for this coming weekend.... rain! :uhoh:  Guess I'll find out how these new tires do in the rain. :thumbs:
Just picked up truck from shop after having 4.10 Yukon gears installed.
I’m happy!
I’m happy!
I'm sure she's a bit more snappy now eh?! I'm on my way to my local tuners shop to pick up my rig. I hope I'm as happy!!
Sent from my SAMSUNG-SM-G935A using Tapatalk
I am very happy. It feels a lot better and I know transmission is happy too!
If you washing your truck causes it to rain here in Texas (hopefully where I live), you will have my sincere gratitude!
It seems to never fail for me... every time I wash my truck and detail it real good, the next day or so it rains. I think I've gone a whole week once or twice without it raining. What part of TX you from? Oh, and Gig 'em! :thumbs:
On 6/13/2018 at 1:39 PM, stassin22 said:
Finally upgraded the radio
What year truck is that one from? I'm assuming it was an easy plug and play install? Been thinking about doing the same so I can have the Android Auto feature that my current one doesn't have.
Jesse, now I'm depending on that rain this weekend. Problem for me is, you probably have a better chance for rain in the Houston area, as I'm west of Austin in the hill country. But the weather man is forecasting a "chance" of rain for my area. The town I live in gets it's water supply from the river that runs through it, and in 2011 the flow of the river almost stopped because there was no rain for close to four months. So I'm thinking about washing my truck this afternoon....
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
