11 minutes ago, jester8798 said:
Curious about this as well. I just put mine in and its angled towards the firewall.
LOL....that's why our engines didn't come with them.  ?
LOL....that's why our engines didn't come with them.  [emoji23]
That picture earlier in the thread lined up so thought it was worth a shot .
2 hours ago, paumat said:
I wouldn’t recommend this. Once you put it in and twist it to lock it in place, it’s angled downward rendering it useless. And it’s a mother lover to remove once it’s locked into place.  Maybe I’m an idiot but I don’t see a way to have this lock in vertical unless you can somehow rotate the locking tabs on the plastic valve cover piece that the tube locks into.
I don't know if you can see the picture, but this locked on straight up the way it should be. It came off of a Corvette LS1. Not sure of the part number.
Weird, I grabbed the part number posted before which looks just like yours.
I know the longer Gen 4 engine part number locks in horizontally, I've tried that one a while ago and it didn't work. The Corvette part works though. I jusy had to cut off the top retaining tab, since this elbow only has a lower tab. I can't get it back off without pulling the valve cover otherwise I'd take another picture.
Thanks. I'll pull mine off and see if I can mod it to work.
6” Fabtech w/ Dirt Logic’s all around. Love the setup! Ride, Install and Part quality are great. Now I need bigger tires! [emoji16]52498de995f1bd3aaefeee2dd8ee1fdd.jpg65797900dd9e8b580be894f023865938.jpg61105230b1f4a11938d9232bc057dd77.jpgc43809e31d62237fd8c8fc112e04d67b.jpg2dd212a413c9364296379a1a0af115e0.jpg
Is this the gen 2 kit that keeps stock track width? Thanks
Here is the one I have. The tabs on the valve cover are at 12 and 6 o’clock. When you align the slots on the tube with the tabs in the Valve cover then fully rotate it until it stops, the tube opening is either angled forward or backward.  You can stop turning when the tube opening is vertical but it is not fully seated at that point.
Yes it is. I think I might have gained 1/2” total so about 1/4” push out on each side up front.
Yah, that's the wrong one then. Pretty sure the valve cover I took it off of came off of a 2001 Z06, because I have the complete engine in pieces in my garage.
