Installed some weathertech floor liners front and back. IMG_0589.thumb.jpg.4d75ee652594b8d7d7f82386790092c9.jpgIMG_0590.thumb.jpg.b5d9a5098fddb2f759f5caae6b4d18ee.jpgIMG_0587.thumb.jpg.c369b80c6f297cd88130de8efba59778.jpgIMG_0588.thumb.jpg.8e4d9f4544046ca66b0cca124a1bb0ea.jpg
I installed those in my truck a few weeks ago. They are really nice!
9 hours ago, qwank said:
Yah, that's the wrong one then. Pretty sure the valve cover I took it off of came off of a 2001 Z06, because I have the complete engine in pieces in my garage.
Then maybe it’s this one. I’m not buying a third one to check though
Put on my new tonneau. Extang SolidFold 2.0. 24720d90ec0214ba9a4ef67c934d3d94.jpg
1 hour ago, DirtyLilPirate said:
Added the 3M Crystalline Series tints on my truck. 20% all around, the darkest of the series.
Hope CHP don't pull you over.
Just ordered some rock lights and the GM bed light kit
What rock lights did you go with? I'm thinking about ordering some.
Sent from my SM-G975U using Tapatalk
I just went with some plain white ones from Amazon. I was considering a Bluetooth one with the different modes and colors but out of all the ones I could find none of them had a true white. Apparently the color from the other leds bleeds off and you can’t get a true white.  Plus the reviews are to mixed for me. Sometimes they work, sometimes they don’t etc. I know they’re cheap but I didn’t feel like taking a chance. I ain’t no party boy, I don’t need my truck looking like it’s parked outside a rave lol.
Got my truck all cleaned up from the winter crud. Now it'll sit in the garage for 2 weeks while it rains every day :(
dont mind my garage.. it’s getting a remodel this summer
Edited by CombsL83
Added photo
1 hour ago, Madcow2020 said:
36 ft/lbs of torque. Lol
Good one
I didn't even bother with a torque wrench.  For the Moogs the instructions say tighten everything down so the threads of the inner rod are flush with the top nut.  Then go 2 more full turns and theyre good.  That's what I did.  Ive had it with those damn end links.
Installed cheap ass Amazon curved light bar, just got to wait til it gets dark to see if actually lights up the road [emoji16]
Sent using Tapatalk - 2014 5.3 WT
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
